    Jul 2005
    West Yorkshire, UK
    fitting Cruise control ?
    i was wondering what all i need to fit Cruise control to my 2002 A4 TDi as it dont have it as standard ?
    i found a site were i can get the stalk and partial wireing loom but not sure if it will work ?
    Mar 2004
    Cheshire
    922
    Re: fitting Cruise control ?
    i think you'll find a lot of info if you search under B6 A4.
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,045
    If it's the same as the S3, you need the cruise control stock and cable and also an additional cable which connects from the ECU to the bulkhead.
    Installation is pretty straight forward (I did mine myself) however you need VAG-COM of a kind Audi dealer to reset you airbag light after installation and to activate cruise control.
    Jul 2005
    rotherham
    40
    Your car is a 2002 A4 which will require the stalk and no wiring is needed but you may require the steering column ecu depending on which one is already fitted because it needs recoding.
    Hope this helps.
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    he can get away with the exsisting column ecu, just plug in and activate cruise in the engine ecu! you may have to recode the column ecu.
