fitting Cruise control ?
Ribzz
West Yorkshire, UK
Website
www.cruisinuk.com
i was wondering what all i need to fit Cruise control to my 2002 A4 TDi as it dont have it as standard ?
i found a site were i can get the stalk and partial wireing loom but not sure if it will work ?
If it's the same as the S3, you need the cruise control stock and cable and also an additional cable which connects from the ECU to the bulkhead.
Installation is pretty straight forward (I did mine myself) however you need VAG-COM of a kind Audi dealer to reset you airbag light after installation and to activate cruise control.
Your car is a 2002 A4 which will require the stalk and no wiring is needed but you may require the steering column ecu depending on which one is already fitted because it needs recoding.
Hope this helps.
he can get away with the exsisting column ecu, just plug in and activate cruise in the engine ecu! you may have to recode the column ecu.
