DNA TuningAWEsome GTI
    Jul 2011
    Teesside
    256
    Post Thanks / Like
    Changing headlight bulbs.....What gloves?
    I'll be changing my headlight bulbs and I remember being told that you should wear gloves? Are rubber surgical gloves ok? Its just to stop the oil from your skin getting on the bulb right?
    vfr800's Avatar
    Feb 2012
    Melting Beans
    223
    Post Thanks / Like
    Quote Originally Posted by JDM82 View Post
    AFAIK - You don't need any particular type of gloves, sure some surgical gloves, nitrile or latex will stop your bare fingers depositing grease on your bulb. But if you get any grease/dirt on the gloves it will deposit on the bulb.
    I read somewhere ages ago that any deposit on the bulb will cause a hot spot which will lead to premature bulb failure.
    Always carefully insert the bulb without banging or touching the glass on any thing.
    So gloves will stop your hands getting dirty.
    When you remove the cover on the head light, apply forward pressure to the cover to compress the o-ring seal before you push down the two clips. IMHO - it saved snapping the clips that hold the cover on.
    Hope this helps.
    Liam
    S3 AMK 2002.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module.
  1. Changing Headlight Bulbs?
    By A3 Sport in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2011, 14:59
  2. Changing headlight bulbs
    By sidibear in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th February 2011, 15:04
  3. Changing Headlight Bulbs - Am I Getting The Type Right?
    By emzino in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th July 2010, 22:30
  4. Changing headlight Bulbs
    By Alex P in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th August 2006, 14:12
  5. changing bulbs?
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 10:51
