EM TuningUnicorn
    kev1000's Avatar
    Jun 2011
    County Cork, Ireland
    147
    Post Thanks / Like
    Error code help please!
    I have these 3 codes 16891,17705,17544.
    From searching on here it seems it could be a vacuum leak.
    Is there other things that can cause these codes, like maf sensor or something else?
    I replaced the kind of breather/valve thing at the back of the engine as there was a definite leak there.
    Engine is a BFB 1.8t.
    Tried spraying pipes but can't find a leak.
    Also idle is a bit lumpy and when revved, it's slow to come back down to normal idle, even when engine is fully warmed up.
    I also think it's heavier on petrol lately??
    kev1000's Avatar
    Jun 2011
    147
    Post Thanks / Like
    BUmp
  1. Help With Error Code
    By S3 Sly in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2011, 23:09
  2. Error Code: 16985 - Internal Control Module: Memory Check Sum Error
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2010, 11:34
  3. Error code
    By dieselfitter251 in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th January 2009, 16:10
  4. Error code...
    By dieselfitter251 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th January 2009, 14:47
  5. ABS error code
    Last Post: 16th October 2008, 15:40
