Volks AutosMonster Motorsport
    Jan 2005
    Midlands
    31
    External temperature DIS not showing - Please Help
    Hi guys
    I've recently upgraded my audio system including running a new power cable to an alpine amp, however upon completion noticed that the external temp DIS is no longer being displayed...any ideas?
    maybe i've knocked a cable or wiring adaptor or the sensor, where is this located please so i can check, any ideas?
    cheers
    adam
    Oct 2004
    Stratford-upon-Avon
    40
    Re: External temperature DIS not showing - Please Help
    Had the same problem on a Passat.
    Disconnecting and reconnecting the battery fixed it. Its worth a try I suppose
