EM TuningBadger5
    Jul 2011
    Post Thanks / Like
    3.2 RUNNING ISSUES PLEASE HELP ME !
    Hi all new to this forum but looking for advice from people in the know
    3.2 audi 2005
    stalls and runs a bit rough,garage have coded it and it has 16395 over advanced intake camshaft a
    when you look at the duty cycle on vagcom the exhaust is about 12 to 13 but intake is about 38
    having searched i think i may have a chain stretch problem
    is it a majour strip to find out
    thanks in advance lee
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    998
    Post Thanks / Like
    It could be the chain but it can be difficult to tell, the only way to be certain is to take out the chain and compare it with a new one, which is a major £2k plus job. Have the garage checked measuring blocks 208 and 208 in the engine module, a reading of 9 or over in either one is an indication of stretching. Can you hear any rattling from the gearbox side?
    Stuck VVT's or a faulty tensioner can cause similar problems, even a faulty coilpack can sound terminal.
    My money is on the chain though.
    Taken from the Ross-tech wiki
    16395/P0011/000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    Possible Symptoms
    Power Loss
    Possible Causes
    Camshaft Adjustment Valve 1 (N205) faulty
    Fuel Pump Relay (J17) faulty
    Mechanical Timing not correct, including Chain and/or Belt timing.
    Possible Solutions
    Check Camshaft Adjustment Valve 1 (N205)
    Check Fuel Pump Relay (J17)
    Check Mechanical Timing
    Brilliant Red S3
    Gone
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
