UnicornEM Tuning
    Dec 2010
    Cambridgeshire
    121
    Post Thanks / Like
    Question A4 B5 auto box issues
    Hi there folks
    I have a 95 A4 2.6se auto and the gearbox started playing up today
    When you slow down to a stop and as it changes in to 1st gear it goes in with such a force (as if your clutch was going in a manual and you had to ram it in ) and the car tries to jump forward. Also when your cruising at a sensible speed in top gear and then put your foot on accelerator very lightly and then take it off its as if your changing down and the car slows down, but you haven't put your foot down enough to warrent a gear change up in the first place.
    Hope its not confusing and I am presuming its the worse scenario of needing another box
    Any help is greatly appreciated
    FOR SALE!
    MK4 Escort RS Turbo Cabriolet in white £1,000 cash sale no offers. PM me for full details.
    And
    Private plate: N11 PJC for sale or swap for some A4 (B5) parts. Any enquiries, message me please
    Jul 2007
    London
    1,574
    Post Thanks / Like
    What's the mileage ? Any record of the gearbox oil beeing ever replaced ? I would start by buying 4-5 L of GENUINE VAG ATF fluid and a strayner (box oil filter to you and me!) and have a good independent change-it for you- someone who knows what they are doing as the filling procedur is rather tricky and require the use of fully registered VCDS... Where abouts are you ? I could help if close to N. London... Regards, Chris- 077 899 12128.
    FOR SALE:
    Dec 2010
    Cambridgeshire
    121
    Post Thanks / Like
    Hi Chris
    The mileage is 135,000 and as for oil change it says in service book that an oil change service was done at 109,304 miles.
    I am up in Cambridgeshire so not close to you But thanks for the very helpful offer, shame.
    I will have to look in to the oil then. I don't use the car that mush tbh and only got it back in late December 2010.
    FOR SALE!
    And
    Dec 2010
    Cambridgeshire
    121
    Post Thanks / Like
    Now I'm not sure if this would be the fault with the learching forward from 2nd to 1st gear, but when I got home today (only second day the gears were playing up) and I pulled up on my drive, I put it in to nuetral and the revs were up to 1,500rpm. Its normally around 800rpm.
    Would this be the problem with regards to the gears? If so, what could be making the revs high? ie sticky accelerator etc. And what could be done to fix it?
    Thanks peeps
    FOR SALE!
    And
