AH FabricationsVolks Autos
Results 1 to 21 of 21
    Nottingham
    72
    In gear acceleration times
    On the 'Old' site there was an extensive post on in-gear aceleration times - like A4 1.8t 70-90 in 5th, 16s etc
    I don't suppose anyone kept any of that info?
    Simon
    South West
    52
    Re: In gear acceleration times
    Here are my times:
    Ok,
    Did some tests.
    These results are for a standard 1998 S reg Audi S4 saloon with 50k miles.
    All tests were perfomed on the flat, using Optimax (half tank) air-con on, engine warm,
    no passengers and a 100kg driver (not sure if that makes a difference or not)
    I did three speed ranges in 4th, 5th and 6th.
    The tests were performed by staying at the lower speed for a few seconds, then hitting
    the accelerator and the start button of the stop watch at the same time.
    (again not sure if this makes any difference, but thought it was 'fairer' than accelerating
    from a lower speed and hitting the start button when the speedo indicated the bottom end
    of the speed range)
    Anyway, here are the results:
    Gear 4th Range 50-70 Time 4 seconds
    Gear 5th Range 50-70 Time 5 seconds
    Gear 6th Range 50-70 Time 6 seconds
    Gear 4th Range 60-90 Time 6 seconds
    Gear 5th Range 60-90 Time 7 seconds
    Gear 6th Range 60-90 Time 9 seconds
    Gear 4th Range 70-90 Time 4 seconds
    Gear 5th Range 70-90 Time 5 seconds
    Gear 6th Range 70-90 Time 6 seconds
    All speeds in MPH (obviously not done on British roads)
    Hope this is of some use.
    DJG
    Reading
    15
    Hi Simon,
    I'm sure I have this somewhere. Will have a look.
    What in particular where you looking for?
    David
    DJG
    Reading
    15
    Simon,
    Having read the Lamba probe thread I am guessing you are keen to see how your car is performing now [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Here are what I have for A4 1.8Ts.
    A4 1.8T Car Magazine
    30-50 9.1s
    40-60 8.9s
    50-70 9.5s
    60-80 10.6s
    70-90 11.9s
    Standard A4 1.8T Sport (my figures, 2 up)
    30-50 11s
    40-60 11s
    50-70 10s
    60-80 10s
    70-90 11s
    AMD chipped A4 1.8T Sport (my figures, 2 up)
    50-70 8s
    60-80 9s
    70-90 9.5s
    A4 1.8T Sport with no boost! (my figures, 2 up)
    30-50 13s
    40-60 13s
    50-70 15s
    60-80 15s
    70-90 19s
    Hope this helps.
    David
    mramage's Avatar
    Scotland
    514
    [ QUOTE ]
    [/ QUOTE ]
    No Boost. How did you manage that [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    Eh?? you remove the turbo or somehting? how'd you get 'real' figures of your not trying?
    Rich
    DJG
    Reading
    15
    Ha, ha
    I had a wastegate rod fail. Basically this leaves the wastegate stuck open, so you don't get any boost. It was fairly common on earlier cars (mine was a 96). Car drove fine except was sloooow. After getting some BS from the dealer I borrowed a colleague's car and measured the in gear times with his and then tried with mine. Big difference [img]/ubbthreads/images/graemlins/confused.gif[/img]
    New turbo under warranty sorted it [img]/ubbthreads/images/graemlins/laugh.gif[/img] My colleagues car had the same failure a few months later
    Then a bit later had an AMD chip fitted. [img]/ubbthreads/images/graemlins/grin.gif[/img]
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    David
    Nottingham
    72
    GRRRRRRRRRRRRRR
    I'm still getting 16s 1 up
    so I'm basically exactly where I was about four months ago! [img]/ubbthreads/images/graemlins/burningmad.gif[/img] [img]/ubbthreads/images/graemlins/cry.gif[/img]
    Since that time it has had the throttle body re-aligned, and now the lambda sensor cleaned, and the boost checked.
    what do I do next - Audi are bloody usless!!
    Simon
    DJG
    Reading
    15
    Sorry to hear it. [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Did you get your car tested on a rolling road and have the power measured? Can't remember. [img]/ubbthreads/images/graemlins/confused.gif[/img]
    If I was you I would take a trip to someone like AMD who know the 1.8T engines inside out and see what they say.
    David
    DJG
    Reading
    15
    Are C & R any good?
    They're in Nottingham aren't they and should have seen plenty of 1.8Ts. Don't have any personal experience of them.
    David
    Nottingham
    72
    It's been to them also - they didn't seem that interested in finding out what was wrong with [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Injector seals are next to be changed - its been on a rolling road, I asked for a power run and the boost checking, when I got back they said 'no problems with the boost it's doing exactly what it should' I aksed what the power oputput was - he said I don't know I didn't record it ????? wtf???
    I was not happy [img]/ubbthreads/images/graemlins/frown.gif[/img]
    I'm still not happy [img]/ubbthreads/images/graemlins/frown.gif[/img]
    DJG
    Reading
    15
    Very frustrating [img]/ubbthreads/images/graemlins/mad.gif[/img]
    Did you mean you have already been to C & R, or AMD.
    Would have thought AMD would have sorted it out for you.
    If your car is taking 16s for 50-70 it must be way down on power. Surprised nothing gross shows up on a VAGCom or even on a standard Bosch analyser.
    Come on boys someone must have some ideas.
    Crafty?
    David
    Nottingham
    72
    16s is for 70-90,but it is still 5s to slow.
    It is C&R it's been to - if I had gone to AMD I am sure I wouldn't have left without a chip [img]/ubbthreads/images/graemlins/wink.gif[/img]
    anyway I think I am going to get it sorted and get it sold - another Skyline is calling.......................
    Simon
    Sweden
    78
    use Vag com or something similar to check for error codes.
    it maybe a MAF or overboosting intermitently and therfore dropping into limp mode. u haven't played with the N75 or wastegate rod ?
    Nottingham
    72
    it's been on VAG-Com, no errors found.
    Other than a forge DV - which was fitted in another attempt to resolve this problem [img]/ubbthreads/images/graemlins/frown.gif[/img] the engine entirely standard.
    MAF has also been cleaned.
    it's not like limp mode becuase it still performs well, I can light up the front tyres if I choose too (18's)
    There are times when it feels better than others though......
    I'll get the injector seals changed over and see if that makes a difference I remember reading something on Audi-world about early A4 sufferign from a problem with them.
    Simon
    DJG
    Reading
    15
    Crafty! Any ideas?
    Being 5s slower 70-90 does not sound like performing well to me [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Sorry!
    I know you have had the boost checked, but your problem sounds exactly like what my car felt like when the wastegate rod failed.
    My car drove fine, but fine for a normally aspirated 1.8 (125 BHP), not fine for a 1.8T (150 BHP).
    It actually took weeks for me to get this sorted. For ages I convinced myself that I had just got used to the car's performance. It took driving my car and another identical 1.8T back to back to realise something was seriously wrong.
    I really wish we could find you a solution.
    A morning at AMD would sort it....
    David
    Sweden
    78
    do few runs with Vag-com logging,, record things like 114 & 115 maybe.. MAF flow would also be good I think it is something like 002.
    Then check the figures against another similar one.
    also check op of N75 valve if this is faulty etc.. then it can lead to surge tyre problems or low boost.
    good luck
    Nottingham
    72
    well at this point in time I am going to change the injector seals on saturday - and give the injectors a clean, see what effect that has, I'll have a look at the DV also just to see if that is still okay.
    other than that I'm pretty much stumped!
    I may well end up taking that trip to AMD - but it does feel a bit like it's defeated me - which is annoying [img]/ubbthreads/images/graemlins/frown.gif[/img] [img]/ubbthreads/images/graemlins/burningmad.gif[/img]
    Simon
    mramage's Avatar
    Scotland
    514
    Simon, sounds like a worthwhile trip IMHO.
    36
    I've used vag-com on my car to log a couple of plots. It was to try and match up with other S2 owners. I plan on doing them again with a flat straight piece of road and working out how much bigger wheels will affect the data.
    Dougal
    Nottingham
    72
    Someone always has to show off [img]/ubbthreads/images/graemlins/wink.gif[/img] [img]/ubbthreads/images/graemlins/tongue.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
    Simon
