DTUKBadger5
Thread: DRL Fitting
    will89's Avatar
    Jul 2010
    358
    Post Thanks / Like
    DRL Fitting
    How/where would be best to wire in a set of DRL's?
    Would like them to come on either with the ignition or with the sidelights. If i cut into the wiring for the sidelights and added them in would i get an error message or is there a better way of wiring them up?
    Thanks in Advance,
    Will.
    bez101's Avatar
    Jul 2008
    3,425
    Post Thanks / Like
    i wire then into the fuse box on with IGG
    will89's Avatar
    Jul 2010
    358
    Post Thanks / Like
    How would I go about doing that? I have never wired anything into there before..
    will89's Avatar
    Jul 2010
    358
    Post Thanks / Like
    Anyone?
    bez101's Avatar
    Jul 2008
    3,425
    Post Thanks / Like
    tap into a fuse thats live when igg is turned on
