Forge MotorsportAdrian S Flux
    Dec 2010
    Post Thanks / Like
    HELP!!!! Heater problems
    Hi i bought a A3 the other day its a A3 1.8T and has a all S3 bits on it, It is a 1998 and the in car heater is very weak?
    When you rev the car above 2000rpm it gets a little warm but on idle it goes stone cold i have changed the termostat and bled the system and still its the same i have also done a head gasget check and all is ok on that side of things?
    I dont know what else it could be, it has the digatal climate control and i dont know if that is the right 1 for the car as my friends one witch is the same model and age has the non digital ones????
    If anyone could help me that would be great
    Craig
    bez101's Avatar
    Jul 2008
    3,425
    Post Thanks / Like
    1st off check the heater pipes are they hot ?
    could be a few things
    CTS
    heater core
    motor flaps
    or may just need bleeding some can be fukkers to bleed
    but id check all hoses are geting hot top an bottom rad and 2 that go to heater
    wheres your temp needle sat at
    Dec 2010
    Post Thanks / Like
    well with the new thermostat its reading about 80 then on idle goes to 90 then fan cuts in??
    cheers for the help
    craig
    bez101's Avatar
    Jul 2008
    3,425
    Post Thanks / Like
    it should run at 90 all day long at temp
    read codes with vcds could be the cts
    Dec 2010
    Post Thanks / Like
    cheers i will give it a go thanks for the quik reply
