Badger5Sky Insurance
    Dec 2004
    heater blowing cold air please help!
    my 98 A6 only blows warm air when im driving. when im at a stop light it starts blowing cold air again. i live in cleveland,ohio and ots been cold. ill warm up the car for 15 minutes and get in to a cooler!! ill start driving and the heat kicks in. has this happened to anyone or does anyone know what the deal is?
    thanks,
    danny [img]/ubbthreads/images/graemlins/cry.gif[/img]
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Re: heater blowing cold air please help!
    sounds like the water/coolant is not circulating properly.
    when last was the coolant system flushed?
    check the level too.
    may also be a pump on it's way out?
    some models have a valve in the inlet pipe to the heater matrix, make sure this is opening/functioning properly.
    Dec 2004
    thanks..ill check it out!
    Dec 2004
    10
    Weak waterpump or poor circulation through the heater core
