AMD TechnikJBS
    Nov 2010
    Post Thanks / Like
    The best way to replace PS fluid?
    My power steering seems to get heavier the warmer the engine gets. As I had to go to the dealer anyway, I bought a couple bottles of the recommended fluid.
    My question is, what's the best technique of draining the fluid from the system? One way (the easiest?) is to use a turkey baster to get all the fluid out of the reservoir , top up to max and repeat a couple times untill the old fluid has just about diluted away.
    Was just wondering what other ways there are.?
    Thanks in advance!
    flat out
    north weald essex
    220
    Post Thanks / Like
    presumably the only otherway is to disassemble the rack ?
    or possibly undo the connections to the ps cooler and steer a bit to pump it out?
    2001 1.8T B5 Black A4 Avant Votex kit and Ecru Leather
    SiGainey's Avatar
    Sep 2003
    North Wales
    476
    Post Thanks / Like
    here#s a guide I did for changing the fluid on a mk4 golf DIY: Mk4 V5 power steering fluid change - uk-mkivs
    '01 AMK, completely standard except for the Ambient Lighting Pack.
