DTUKRevo Technik
    Nov 2010
    Post Thanks / Like
    How to fit Auto Lights/Wipers & Auto Dim Mirror to 2006 RS4
    Hi,
    I am trying to fit Auto Lights / Wipers & Auto Dim Mirror to my RS4. I have purchased the following from Audi and fitted so far:
    Rain sensor: 8K0955559A
    Mirror: 8R08575114PK
    Light Switch ( With Auto Function ): 8E0941531D5PR
    Wire Loom for Sensor: 8E1971100KS
    I have also coded it in Vag Com, but still no luck. The mirror dosn't seem to have power and all i get is Can bus fault code when I code the auto wipers in?
    Any Help would be appreciated please.
    John
    18,280
    Post Thanks / Like
    Have you wired anything to the mirror itself as the sensor is seperate wiring to the mirror itself.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Nov 2010
    Post Thanks / Like
    The new loom we fitted had the plug for light and rain sensor and plug for mirror. All is plugged in.
    18,280
    Post Thanks / Like
    It would seem its plugged in wrong then mate as its not detecting it based on your posts as the mirror should have a tiny green light showing when powered on.
    Go through elsa & recheck your wiring & also check your central electrics module supports the feature, compare the board with others who have this feature already to see if its compatible, tbh if its an rs4 then the board should be the highline version anyway.
    Check any fuses aswell.
    Nov 2010
    Post Thanks / Like
    Whats elsa?
    John
    18,280
    Post Thanks / Like
    Some bird from coronation street
