Badger5Monster Motorsport
Results 1 to 7 of 7
    Feb 2004
    Clearfield, PA
    892
    HELP ALL ASP PROGRAMMERS!!!
    if your spot on with ASP please PM me.. having major problems with database paging.... [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,116
    Re: HELP ALL ASP PROGRAMMERS!!!
    ASP sucks! PHP is rocks!
    PM me is you need help though... I know a few decent ASP programmers.
    Feb 2004
    Clearfield, PA
    892
    asp is alot better for what i need it for..
    need a database paging script that actually works instead of the carp examples you get on websites..that dont work.. lol
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,116
    Can you give a better description of what you are wanting?
    Feb 2004
    Clearfield, PA
    892
    ok heres what i have at the moment.
    this script shows alllll the data in the table.
    the fields are as follows
    SubTitle= Request.Form("SubTitle")
    Topic = Request.Form("Topic")
    SubPicThumb = Request.Form("SubPicThumb")
    SubIntro = Request.Form("SubIntro")
    SubDate = Request.Form("SubDate")
    SubSplash = Request.Form("SubSplash")
    SubMain = Request.Form("SubMain")
    SubKeyword = Request.Form("SubKeyword")
    the script to show all is
    'declare your variables
    'create an ADO connection and recordset object
    Set Conn = Server.CreateObject("ADODB.Connection")
    Set Recordset = Server.CreateObject("ADODB.Recordset")
    'declare your SQL statement that will query the database
    sSQL = "SELECT * FROM articles"
    'define the connection string, specify database driver and the location of the database
    sConnString = "DRIVER={Microsoft Access Driver (*.mdb)};" & _
    "DBQ=" & Server.MapPath("/db/vagdb.mdb") & ";"
    'Open the recordset object executing the SQL statement and return records
    conn.Open sConnString
    recordset.Open sSQL,conn
    'first of all determine whether there are any records
    If Recordset.EOF Then
    Response.Write("No records returned.")
    Else
    'if there are records then loop through the fields
    Do While Not recordset.EOF
    Response.Write("<p><table width=537 cellpadding=0 cellspacing=0 border=0 align=center><tr><td width=3 rowspan=5></td><td width=100 align=center rowspan=5><img src=" & recordset("SubPicThumb") & " border=1 bordercolor=#000000></td><td width=3 align=center rowspan=2></td><td width=294 valign=top><font face=verdana size=1 color=#999999> <b><font face=verdana size=1 color=#999999>[</font></b><a href=" & recordset("Topic") & "/><b><font face=verdana size=1 color=#999999>" & recordset("Topic") & "</font></b></a><b><font face=verdana size=1 color=#999999>]</font></b> <a href=article.asp?keyword=" & recordset("SubKeyword") & "><b><font face=verdana size=1 color=#999999>" & recordset("SubTitle") & "</b></font></a></td></tr><tr><td><font face=verdana size=1 color=#999999>" & recordset("SubIntro") & "</font></td></tr><tr><td height=2></td></tr><tr><td align=right colspan=2><font face=verdana size=1 color=#999999>" & recordset("SubDate") & " </font></td></tr><tr><td height=2></td></tr></table></p>")
    'move on to the next record
    Recordset.MoveNext
    loop
    end if
    'close the connection and recordset objects and free up resources
    Recordset.Close
    Set Recordset = Nothing
    Conn.Close
    Set Conn = Nothing
    now i want it to show 5 records and then at the bottom of the 5 records show pages 1,2,3,4 obviously depending on how many records there are. its something they use on all the search engine when over there are loads of results.. also i want only the 5 to be collected and then when u click 'page 2' is then collects them.. i dont want the script to collect all the data from the table as i want it as quick as possible.
    hope this explains what im after.. :P
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,116
    If you only want to collect the first 5 records, then use the MySQL statement:
    SELECT * FROM articles LIMIT 5
    You'll also need to find out how many records you have and do a calculation of total records divided by 5 and round it up - that how many pages you'll have.
    SELECT COUNT(*) FROM articles
    or
    SELECT COUNT(*) AS totalrecords FROM articles
    Feb 2004
    Clearfield, PA
    892
    humm... will have a blast tonight....
