Put a new battery in My key Now it wont work !
ChuckH
Put a new battery in My key Now it wont work ! Car is an A4 Avant 2006 B7 chassis I fitted a new battery Then followed the handbook IE Open the car with the key. Then press the unlock button Then put the key in the ignition switch and turn on Then it should work But it doesent ! Any ideas please ?? TIA.................
Not sure if this will help but when i replaced the battery all i did was unlock the car with the key then start the engine. after that it managed to work. Hope it works for you.
i would check your new battery first!
your key may have lost its memory this may help
[FONT='Verdana','sans-serif']Re: Programming Keys[/FONT]
[FONT='Verdana','sans-serif']Programming[/FONT][FONT='Verdana','sans-serif']
When
[/FONT]
[FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] added or replace
system malfunction
How
NOTE: max of 4 keys can be programmed (one at a time).
memory positions of existing keys can be identified using diagnostic equipment
If Diagnostic equipment available:
locate vacant memory position for new [/FONT]
locate memory position for [/FONT]
[FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] to be replaced
carry out programming procedure for this [/FONT]
[FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] only
if diagnostic equipment not available: Obtain and reprogram all keys
NOTE: Existing [/FONT]
[FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] memory positions will be overwritten[/FONT][FONT='Verdana','sans-serif']
switch ignition ON, Use [/FONT]
[FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] not fitted with [/FONT][FONT='Verdana','sans-serif']remote[/FONT][FONT='Verdana','sans-serif'] control
Manually lock driver's door using [/FONT]
[FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'].
Complete the following within 30 seconds:
Within 5 seconds press unlock button on first [/FONT]
[FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] once (programs memory positions 1)
Indicator lamps flash once to indicate signal received.
Wait 5 seconds.
Press unlock button once to confirm programming.
Vehicle unlocks. Program mode deactivated.
Switch ignition OFF. Remove [/FONT]
[FONT='Verdana','sans-serif']Key[/FONT][FONT='Verdana','sans-serif'].
To program remaining keys into memory positions 2,3 and 4. Carry out the complete procedure below for each [/FONT]
[FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif']:
Switch ignition ON. Use the [/FONT]
[FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] not fitted with [/FONT][FONT='Verdana','sans-serif']remote[/FONT][FONT='Verdana','sans-serif'] control.
Within 5 seconds press unlock button at 1 second intervals, as follows:
Twice for memory position 2 (2nd [/FONT]
[FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif']).
Three times for memory position 3 (3rd [/FONT]
Four times for memory position 4 (4th [/FONT]
Indicator lamps flash once every time unlock button is pressed to indicate signal is received,
Wait 5 seconds.
Press Unlock button once to confirm programming.
Vehicle unlocks. Programming mode deactivated.
Switch ignition OFF, Remove [/FONT]
NOTE: Ignition MUST be switched OFF between each [/FONT]
[FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] programming procedure.[/FONT][FONT='Verdana','sans-serif']
Memory erase procedure
When
Lost [/FONT]
[FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] fitted with [/FONT][FONT='Verdana','sans-serif']remote[/FONT][FONT='Verdana','sans-serif'] control
Incorrect number of keys supplied with vehicle.
Switch ignition ON.
Press unlock button 5 times, at one second intervals.
Indicator Lamp flash once every time unlock button is pressed, to indicate signal is received.
Wait 6 seconds.
Press unlock button once (to confirm erase procedure)
[FONT='Verdana','sans-serif']key[/FONT][FONT='Verdana','sans-serif'] from ignition.
[/FONT]
[FONT='Verdana','sans-serif']Remote[/FONT][FONT='Verdana','sans-serif'] control should no longer operate system.
Obtain and program all keys.[/FONT]
dont know whats goin on with that last post i just coppied and pasted a word doc and came with all that added font crap
anyway if u want drop me a pm with u email and ill send it ur way
Paste it into notepad, then copy and paste it into ASN - this will get rid of the formatting markup.
________________________________________
Programming
When
key added or replace
system malfunction
How
locate vacant memory position for new key
locate memory position for key to be replaced
carry out programming procedure for this key only
NOTE: Existing key memory positions will be overwritten
switch ignition ON, Use key not fitted with remote control
Manually lock driver's door using key.
Within 5 seconds press unlock button on first key once (programs memory positions 1)
Wait 5 seconds.
Switch ignition OFF. Remove Key.
To program remaining keys into memory positions 2,3 and 4. Carry out the complete procedure below for each key:
Switch ignition ON. Use the key not fitted with remote control.
Twice for memory position 2 (2nd key).
Three times for memory position 3 (3rd key)
Four times for memory position 4 (4th key)
Wait 5 seconds.
Switch ignition OFF, Remove key.
NOTE: Ignition MUST be switched OFF between each key programming procedure.
When
Lost key fitted with remote control
Switch ignition ON.
Wait 6 seconds.
Switch ignition OFF. Remove key from ignition.
Remote control should no longer operate system.
Thanks Andy ! Unfortunatly it hasent worked I put the Blank key (The slim one that normaly never gets used) into the ignition and switched on Then locked the door with the key Iwas trying to program Then within the 5 seconds pressed the unlock button But the indicators did not flash to aknowledge the signal ????
ive never tried it yet i need to get me new spare cut first, i came across it on this site and saved it for when i get round to doing mine, could there be a problem with your remote?? or does anyone know if this procedure is just wrong??
Andy there is a small LED on the key which flashes when any of the function buttons are pressed The one on the faulty key flashes just the same as the one My wife has . But I just cant get it to lock or unlock the doors since fitting the new battery Ive changed the battery again in case I had fitted a faulty one But as yet No good ! Audi want £60 to do the job !
Im wondering if investing in Vag Com So I can sort iot out as Id rather put 60 quid towards that than pay it to Audi for a 2 minute job !
Genuinly appreciate Your help ........................................
just found this mate from another thread, worth a try
Right everyone cheers for all your replys , was just about to go to the stealers when i thought id have a quick look through my manual, it tells you how to synchronize the key fob! It was easy press unlock/lock on the fob then within 30 secs put the key in the lock and either unlock or lock the car and it will re-synchrozine its self!
Cant believe the stealer wanted £80 to do that! Robbing Bast**ds
Still got to fork out £180 for a spare key though
Cheeers for all the info again
just checked the manual and yhe above procedure should re-sync it
Just tried it and it doesent work !
But I have a plan A cunning plan ! It involves s small quantity of unleaded and a Swan Vesta .............................................................
no body local got vag-com??
better than parting money with the stealers!
keep me posted mate as i say i am yet to re-program my spare
Lol sorry im being a dum *** again! Didnt read it right, thought u meant the car battery! :blush:
