Results 1 to 19 of 19
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,062
    Exclamation Radiators Cold at the Bottom!! (Plumber advice required)
    OK guys, some help required please now that the cold is kicking in!!!
    I have a combi boiler in the house and a couple of the radiators in the house are warm at the bottom and roasting at the top.
    I have carried out the following steps to see if it makes any difference, but nope....
    Beled rads, so water is coming out of them, therefore no air, got temp setting on the highest one on the rad, pressure is ok on the boiler, the pipes going into the rad from the floor are hot, and the water released from the rads is clear, so no sludge im presuming, though i maybe wrong.
    Can anyone else advise on what needs to be done, or what I can do to heat my room up!!
    Thanks in advance
    Nilz
    diesel-a4's Avatar
    Stoned As Fuk
    162
    if its bottom entry fed then i wud guess the rad is blocked.
    is it heat the whole way across the top and half of the bottom or is the whole bottom cold from one end to the other.
    Nilz's Avatar
    Apr 2006
    10,062
    It is bottom entry fed....
    The whole top of it is hot and it seems like parts of the bottom are cold, its not from end to end (if that makes sense).
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    sounds like they are full of sludge, have you got adative in your radiator water ??? how old is the system ???? the only way the bottom can be cold is if you have a great deal of sludge in them. Nasty black stuff that will stain anything it touches.
    you could try isolating one radiator, drain it down, carefully remove it and take it outside then flush it out with a hosepipe. If this clears a load of black cr@p out of it then it might be worth draining the whole system and doing all the rads then refill the system with water and a addative like fernox
    red to red black to black blue to bits
    Nilz's Avatar
    Apr 2006
    10,062
    I think the system is only about 5 years old, and dont know if it is sludge as when the water comes out of it when bleeding, its literally clear as tap water, so if it was sludge, wouldnt it be dirty???
    Also, its a combi boiler, so will that still have a tank, coz im pretty sure i dont have a tank in the loft...
    thats me
    Sep 2004
    west yorkshire
    3,762
    no tank with a combi, the water can still run clear even if the there is sludge in the bottom. Its not on micro bore is it ??? Ive never had to deal with that stuff and it may act differently. But radiators normally suffer being cold at the top not the bottom
    Jun 2003
    World of my own
    9,813
    If it's not sludge then it could just be that the rads have not been balanced causing the water to circulate too quickly not giving it time to warm up the bottom. Check the lockshield valves with the appropriate tool to see if they have been adjusted. The lockshield valve is the return valve, the one with the tamperproof cap on it (not the adjustable inlet valve). If they are completely open then the rad has not been balanced and this is why you have the problem you describe. You need to wait for the heating system to be fully warmed up then with the inlet valve completely open, fully close the lockshield valve, then open it half a turn and wait 2-3 mins to see if the rad heats up, if not open it another half turn and so on until you have full heat top & bottom.
    Alex Turner
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    as above: sludge or balancing needed
    ^^ In my opinion
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    ^^ In my opinion
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    its balancing all right, this has to be done properly, and the TRV isn't always on the inlet, it depends on the TRV. but balancing is definitely done with the lockshielded valves, wind them all down to closed and then open them all up a bit, a bit at a time so that you slow down the flow and even it out through all the rads. Make sure the TRV's are fully open before you start.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    thats me
    Sep 2004
    west yorkshire
    3,762
    I can see why that may have to be done , although I know all mine are wide open.
    Nilz's Avatar
    Apr 2006
    10,062
    How do i know what is open and what is closed??
    Im about to give it a go, but just want to make sure im doing it right....
    Just to confirm, I need to keep the temp knob on full on one side of the rad and then the other side, take the cap off and turn the little valve thing, on each rad at a time???
    Jun 2003
    World of my own
    9,813
    Fully clockwise is closed, fully anticlockwise is open.
    If you have a look at your bathroom taps, they use the same technology!!
    Alex Turner
    cornish_a3_turbo
    the other way 4 australia tho eh???
    lol
    Nilz's Avatar
    Apr 2006
    10,062
    Right guys thanks for all your help, I will give it a go and see what happens, I will let you know....
    thats me
    Sep 2004
    west yorkshire
    3,762
    righty tighty, lefty loosy
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Quote Originally Posted by fingermouse View Post
    lol
    Chris
    See my images @
    Nilz's Avatar
    Apr 2006
    10,062
    LOL....thanks guys, i did give it a go and actually turned the temp up on the boiler considerably and it looks like we are 'cooking on gas'!!!
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by nilz18t View Post
    Yars ago when I had GCH installed in a flat I had, the installer told me to have the boiler thermostat at max all the time as the radiators are designed to have 80C water flowing through them.
    Just something to consider.
