Sky InsuranceChris Nott
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    Audi goes with new compressor and trick diff for new S4
    Hi folks,
    We received information today regarding the new S4, and a couple of things jumped off the page at me which seemed pretty interesting...
    The N/A 4.2L V8 lump is being replaced by a forced-induction V6 unit, but this time Audi have decided to use a supercharger, stating that apparently it's more effective than even two turbochargers.
    There's an extension to the quattro system too - of course we all know that they're using a 40/60 (F/R) split to give a bit more of a lively drive these days, but they've developed an 'active sport differential' for the new S4 which can vary torque between the rear wheels to give the outside wheel a bigger shove in the bends. That coupled with the drive select system which allows you to sharpen up engine, suspension and steering characteristics on-the-fly should make for a very interesting drive...
    Anyway, I posted the full press release here - but I just tought I'd drop the two juiciest bits in the forum...
    Regards,
    Rob.
    PS> A couple of photos here too, there are technical difficulties with pictures at the front page which are being worked-on at the moment...
    The truth they're trying to keep from you is that IPv6 has nothing to do with address space; we're actually running out of full stops.
    Kontraband's Avatar
    Dec 2007
    1,998
    MMMM, I quite like that... in saloon. Could be the car that stops me shifting back to the dark side!?!?
    What was the previous S4s CO2 as it only says there is a 30% reduction... of what??
    EDIT>> Ignore that bit... "while emitting 225g of CO2 - 30 per cent less than its predecessor (S4 V8 manual 322g/km)."
