Sky InsuranceChris Nott
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    relay wiring question
    question for you electricains out there.
    im trying to wire up a flashing led to come ON when the ignition is OFF and to turn OFF when the ignition is ON.
    the reason is i want to put a flashing led in the pickup/cover off my new l200 warrior, i dont need an alarm just a visual diterent, as there nothing left of real value in there over night etc, and the main cab of the warrior is already alarmed etc.
    i have a 5 pin relay (pins 85,86 87,87a,30) but cant work out which to wire to etc and where to take feed from., the led has only 2 wires
    i followed the instructions from maplin where i got the led from but with no luck
    http://www.maplin.co.uk/module.aspx?...5&doy=16m6#faq
    any ideas??????????
    Carpy25's Avatar
    Oct 2007
    272
    30 is the live feed 12v
    85 to earth ,along with the earth off the led
    86 an ignition live
    and 87a to the live side of the led
    how the relay works is with the ign off the live comes in 30 go through the relay out 87a via the led to earth, switch the ign on the relay switchs so that the live from 30 now goes out the 87 terminal thus cutting the 12v to the 87a putting the led off , the relay is switched by applying a 12v feed to the 86 and by making sure the 85 is earthed
    one last thing led's only work one way make sure the 12v is on the right wire or it will never work relay or not
    Rob
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    Thumbs up
    thanks alot mate ill try that one night this week when i get chance
