Volks AutosChris Nott
Thread: Clay
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,090
    Clay
    Anyone used it or heard of it??
    Apparently its alot cheaper and is designed to be used with tap water as a lube...
    http://www.bilthamber.com/autoclay.html
    Jun 2008
    Edinburgh
    80
    I have it.
    Its a bit harder than most other clays, but pre-soaking it in warm water makes it perfectly pliable. Bilt Hamber stuff on the whole is excellent. Used a fair bit of their stuff on my project restoration.
    Nilz's Avatar
    Apr 2006
    10,090
    Hmmm sounds good, might have to invest considering its a bigger clay bar and its cheaper...and it can be used with water, is that right yea??
    Jun 2008
    Edinburgh
    80
    Just water is fine.
    I've used it right after washing car with standing water.
    It does sometimes grey the water which dries on the car but a quick wipe sorts that.
    The autobalm stuff they do is excellent as well. Fills swirls and scratches amazingly well. Quite durable. Contains cleaners as well, so even after claying you might notice the pad getting dirty while applying it.
    Nilz's Avatar
    Apr 2006
    10,090
    Cheers Shug, will bear that in mind when having a go ;-)
