AH FabricationsEM Tuning
Results 1 to 11 of 11
Thread: DIY Help!!
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    Angry DIY Help!!
    Decided to put a punchbag up in my garage. Drilled into the wall, inserted rawl plugs. Lined up the bracket and started to tighten up the screw\bolts. They all snapped when they started to get tight. Went an bought more. Re-drilled etc and they did the same. What am i doing wrong?
    Built in Germany, Perfected in England
    karl7900's Avatar
    Nov 2006
    1,402
    Sounds like your using the wrong size of drill bit, rawl plugs or screws. The size and length will depend on the weight of the bag and the hammering it is going to get.
    If you are using red Rawl plugs then a 6.0mm drillbit and 8x1 1/2" screw should do. Also when you are drilling, just drill the hole once. Don't be reaming the hole to make it bigger.
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    I'm using a 10mm drill bit with m8 screws. The ones supplied are about 3 inches long. I'm gonna try buying some shorter ones. The rawl plugs are white or sorta see through really.
    karl7900's Avatar
    Nov 2006
    1,402
    Try using masonry screw bolts. You drill the correct size hole then screw the blots straight into the wall. I use them in work to secure large floodlights and they are a good job.
    karl7900's Avatar
    Nov 2006
    1,402
    karl7900's Avatar
    Nov 2006
    1,402
    Best bet are the ones with a bolt head then you can use a ratchet to tighten it up.
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    IMO they heat up, that's why they are breaking. Get better screws as karl7900 advised.
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    I got shorter screws in the end and they did the trick. Hopefully it won't fall down lol.
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    Fisher fixings work quite well, Id be tempted to no nail it to the wall as well as screwing/bolting it , think it will take some hammer lol
    red to red black to black blue to bits
    DriveByShooters's Avatar
    Editor Audi-Sport.Net Magazine
    Oct 2006
    Kettering
    1,197
    Quote Originally Posted by Randomjim View Post
    Could use it as a kick bag if it does!
    Freelance Automotive Photography
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    Quote Originally Posted by cal1470 View Post
    Ha ha yea might have to, not going through all that aggro again lol.
