Volks AutosSky Insurance
Results 1 to 9 of 9
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Need advice from sparkies
    Well its getting baltic up here in scotland so stuck on my storage heaters for the first time in a while just banged them up full blast both dials
    Was away for a few days and when i came back they were really hot then the next day they were stone cold and are still stone cold.....spoke to a local guy and he said that they have probably tripped with heat and i need to reset .
    Q:Is that true and how do i do that or what else can it be
    Very cold steve
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    Sep 2007
    Ellesmere Port
    160
    If all storage heaters are off then check your main fuse in the meter cupboard and see if thats on.. there is prob a seperate switch an fuse for them.
    If it's one then check fuse in the wall, most have a local fuse in the wall outlet.
    Audi A3 2.0 TDI Sport, Hybrid Turbo, Sat Nav RNS-E, Bluetooth, Bose, Parking Sensors, Custom Bluefin Map, Black Diamond Drilled and Groved Front Discs, Black Diamond Preditor Pads (All Round), Roof Spoiler, Cruise Control.
    Jun 2003
    World of my own
    9,813
    Storage heaters are the work of the devil, no wonder you're cold.
    Mar 2005
    Back O' Beyond
    82
    Maybe some info on here www.diynot.com
    2004 Black S4 Avant.
    RNS-E, Glovebox Changer, Bose, Cruise Control, Black Leather Interior, Heated Front Seats, Sony Bluetooth Handsfree, Rear Parking Sensors, Blinds, Lighting and Storage Pack.
    Slim-line DVD player to be fitted soon!
    karl7900's Avatar
    Nov 2006
    1,402
    Dedending on the make and model of the storage heater, there may be a thermostatic cut-out inside the heater. Or the contacts on the thermostat hav stuck in the open position. Any competant sparkie should be able to tell you if either of these is the case. Don't open the heaters if your not electrically minded yourself as you will then expose the internal workings of the heater.
    Are the heaters controlled by a timeclock or a teleswitch provided by your electric supplier? If its a timeclock and all the heaters are not working then that could be at fault.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    teleswitch from Southern Energy....ok with electrics so will see whats up
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    karl7900's Avatar
    Nov 2006
    1,402
    Are none of the heaters working now? If so, then I would check the fuses in the heating board and also check the supply coming into that board.
    If the supply is controlled by a teleswitch then the board should become live at about 11o'clock in the evening. Check that the board is powered up with a multimeter after this time. If it is dead then the teleswitch is possibly at fault.
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    Glesga,home of the rain god!
    1,836
    Stevie just buy you and the wean a good fleace save money to spend on the car ! lol
    I bought a convertable in the wettest country in the world who says Scotsmen dont have a sense of humour !
    "Lets fire up the Quattro" DCI Gene hunt,,,,,,,ashes to ashes
    Jan 2007
    Renfrewshire
    118
    I repair storage heaters and depending which type there could be various problems. If your fuse board has power around 11pm-12am then i would check inside the heaters themselves. Make sure the power is off before opening the covers(there can be other supplies live in there eg 24hr fan circuits!) At the top there might be a ceramic connector block which holds the thermal link this melts if the heater gets too hot. Check to see if its melted, if so, note the colour on the ends of the link as that denote's the melting point of it.
    hope this helps
    A4 Avant 2.0tfsi S-Line Quattro 2010, Misano Red, thinking about bluefin when i have the cash
