Chris NottAH Fabrications
Results 1 to 14 of 14
    larry1's Avatar
    Feb 2005
    Dublin, Ireland
    23
    Unhappy Nervous breakdown time.. cement splashes
    My 2003 BLACK A4 AVANT got splashed with cement somewhere during the week. Cement splashes everywhere! I didnt get the chance to clean at the time. spent 2 hours scratching it off today as carefully as possible but my paintwork is fcuked.. can't believe it. Tried some T cut but it only took the edge of the scratches. Please tell me I dont re a respray job.. help me please
    a4quat's Avatar
    Aug 2006
    middlesbrough
    366
    i deliver concrete for a living, what i use on my mixer truck is hydrochloric acid which pulls it off straight away but it makes the paintwork really dull after many uses. NEVER scratch it off!
    03' S4
    00' A4 1.8TQS (sold)
    Seat Ibiza GTI (track day car) (sold)
    Seat Leon (her car)
    DRZ 400S
    auditek's Avatar
    Oct 2006
    fortrose scotland
    287
    fukt .........paintjob. my van got splatted last year, thought it would knock off. similiar to a leach. nah nah took the paint with it...... so i smashed windows on jcb at weekend, monday it got fixed, did it again following weekend, ****ers !
    ManicMunky's Avatar
    Sep 2006
    Chorley, Lancs, UK
    311
    find the builders, and sort it out
    - Andrew
    d3fy's Avatar
    Sep 2005
    Sheffield
    1,411
    I would start to ask around on here for some solutions,
    http://www.detailingworld.co.uk/
    2.0T Quattro SLine, now 320d Sport Touring
    larry1's Avatar
    Feb 2005
    Dublin, Ireland
    23
    Quote Originally Posted by BaBs
    Not an option.. no idea where it happened.
    Regarding the scratches .. any good solutions?
    ManicMunky's Avatar
    Sep 2006
    Chorley, Lancs, UK
    311
    can you not retrace your steps? figure out where you've been?
    - Andrew
    larry1's Avatar
    Feb 2005
    Dublin, Ireland
    23
    No point now. too late & how could I prove it
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    I had a similar problem mate, so I feel for you. I was following a cement truck a bit too close and got a few splashes on, clean it off as best as I could but have 3 very fine scratch marks, hope you find a (cheap) solution soon.
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    205man's Avatar
    May 2006
    worcestershire, uk
    1,014
    you can soak the splashes with hot water/shampoo, and keep soaking them, not letting them dry, the cement will go softer and can can be removed by very gentle rubbing, it may still leave some faint mark but they can be polished out
    the other way is to us a jet wash, preferably one with an oscilatting spray and start with jet away from the car slowly moving in until they lift and so not risking paint to much, again then just polish
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Coca Cola contains phosphoric acid which when applied to cement will break it down and make it easier for it to come off, just wash the coke off fully when the cement is off.
    This works on clothes also!
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    DiscoPanda's Avatar
    Jun 2007
    Glasgow, Scotland
    158
    Small amounts of cement (now turned to concrete) will dry up and I imagine will fall off over time with some help from some of the methods mentioned.
    Is it noticeable? If not I'd be inclined to leave it alone as removing it could make it worse.
    atc
    Nov 2005
    Essex, UK
    105
    If it were me I'd take the car to a good trusted preferably recomended paint shop (don't panic, not for a respray) and ask them for advice. They have all kinds of clever paint finishers and tools, much better than T-Cut so they should be able to help. It may cost 60-100 to have them buff the car up but it'll be worth it! You could try stuff like rubbing compound or various grades of G fluid but your more likely to do harm than good, a paint finisher will know how far he can go with the laquer before its knackered. I guess worts case would be to have the car re-laqured cheaper than a respray!
    Sep 2005
    London
    197
    I use 1500 grit for the bad scratches, 2000 grit to finish then a cutting compound and buffer followed by a polish.
