EM TuningChris Nott
Results 1 to 17 of 17
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    Tyre bulge! instant change?
    I have a bulge about the size of a 2 pence piece in one of my tyres. they're not that old and at 150 quid a piece not cheap. the bulge is sticking out 4ml or so. I doubt it will pass its mot which is 6 or so months away. how dangerous is it basically? And given that it along with the other on the axel are partly worn will I need th change both? if that wasn't bad enough he rears will need doing in 6 months too
    they're pilot sports on 225-40-18's
    "If that's the Turbo Fairy knocking send her round to ShineyDave's"
    smitch's Avatar
    Sep 2006
    1,585
    Always change tyres in pairs.
    I certainly wouldn't feel safe driving round on a tyre with a damaged wall.
    S4.
    Oct 2005
    Essex, UK
    1,222
    You should change the tyre, you could have a blow out at any point, ( & at 70mph on a motorway), that wouldn't be good
    VW Passat 2.0 TDI Sport
    2005 - 55 reg.
    A4 Avant 1.8T Sport - Sold March 09
    1997 - R reg.
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    All of above and its a 3 point and 60 quid offence if stopped by the police.
    Its damaged so change it, don't be putting any form of lotion or potion on it as that will attack the rubber and make it worse. Once it's damaged it's damaged i'm afraid!
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    Jun 2003
    World of my own
    9,813
    This happened to me and eventually the tyre let go on the M27, completely came away from the sidewall all round. Luckily it was my wife who was driving at the time (and it was her who clipped a curb to cause the bulge in the first place). It was on the offside rear so she managed to keep it under control, no harm done, but it could have been disastrous. Get it changed.
    Dec 2006
    N.Ireland
    369
    i would immediately change the tyre.. its weak and could quite easily blow out at any stage.
    hint... keep away from kerbs and pot holes in future
    smitch's Avatar
    Sep 2006
    1,585
    Quote Originally Posted by AndyMac
    This happened to me and eventually the tyre let go on the M27, completely came away from the sidewall all round. Luckily it was my wife who was driving at the time.
    Nice to know you were concerned Andy.
    S4.
    rodenal's Avatar
    Oct 2006
    1,982
    I'd change the tyre matey, its not safe basically - i wouldnt bother getting 2 tho especially if its fairly new
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    is it kerb damage or a tyre issue, i just had a Avon ZZ3 replaced because the inner sidewall was split all the way round, turned out to be a manufacturing defect.
    fortunately with it being on the inside there was no way they could have been kerbed so they didn't really have a leg to stand on.
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Jun 2003
    World of my own
    9,813
    Go and get the tyre turned round on the wheel so the bulge is on the inside and then you could claim it couldn't possibly have been curbed and must be a defect.
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    Talking
    Well i've had my alloys re finnished sooooo..... i still have the receipt somewhere, i was thinking of going back to the place and crying defect... no rim damage you see
    Onlyme's Avatar
    Oct 2006
    593
    What I would do is change the tyre ASAP and ask for the tyre with the bulge, I would then drive to some Chavvy area and dump it and then watch for hours of fun whilst the little chavvy kids try to get the tyre over the tallest lampost, you could even take your mates and have bets on which little chavvy will actually chuck it high enough to loop it over the lampost
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    The bulge you describe is called a carbunkle, this is where the plies in the wall have given way and the pressure within the tyre has pushed out the wall in the weak spot, it normally follows a kerbing or similar.
    When you drive and pressure is put on the tyre, it can cause the carbunkle to burst, causing a large hole in the wall which will lead to rapid deflation and possibly loss of control.
    Change it asap.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    Quote Originally Posted by LottieA3
    Try putting some witch hazel on it and after a few days it will go down...
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    Glesga,home of the rain god!
    1,836
    deff change tyre, not worth a risk a blow out on a motorway ,
    if you own a Quattro , would recomend a set of tyres
    I bought a convertable in the wettest country in the world who says Scotsmen dont have a sense of humour !
    "Lets fire up the Quattro" DCI Gene hunt,,,,,,,ashes to ashes
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Quote Originally Posted by fallmonk
    Tell me about it!!
    Chris
    See my images @
    Onlyme's Avatar
    Oct 2006
    593
    Quote Originally Posted by A4Quattro
    Tell me about it!!
    What you want to know, as im listening !
    I nicked my last lot of wheels from the Unigate milkman, the car now sticks to the road like glue but im f----d if i can get the bugger to go faster than 5mph
