Volks AutosEM Tuning
    Zoom Zoom's Avatar
    Bunny Boiler Magnet
    Mar 2007
    Sheffield
    Chipping / xenons, Sat nav and stuff? Wisdom required.
    Hi here I go again with the questions within 24hours but...
    What mileage / age is it bad to chip...or doesn't it really matter? The car I have in mind is a 2001 S3 with 60K on the clock.
    Does an 2001 S3 Sat Nav display a compass as I've seen on some pics of Audi Sat Nav's? Can you upgrade the map software and include Points Of Interest i.e...Speed Camera locations?
    Can I fit some gadget to bluetooth through the stereo/TV/Sat Nav?
    And finally regarding the current S3 i'm considering buying, when I put the lights on..the driving lights are the blueish xenons but the side light bulbs and full beam are the yellow(usual on most cars) colour. I thought the main beam would of been extremily bright xenons.....the yellow ones are just garbage..
    PJ
    benw123's Avatar
    Oct 2004
    Herts, UK
    1,863
    Chipping (or remapping) a car is really dependent on the condition of the engine, and the car as a whole. If it's been well looked after, with clean oil and a good power output in standard trim a remap will be fine. A good tuner will check the car over and advise you of this.
    I'm not totally sure if the RNS-D shows a compass on-screen, but my RNS-E provides a compass in the DIS display, between the dials (simply N, NE, E, SE etc). You can upgrade the software with the latest maps, but you cannot add POIs like speed camera locations. It's just not possible right now unless Audi release a DVD with this included.
    Bluetooth is no problem - in fact, you can fit Bluetooth kits to all models regardless of the stereo fitted. There's an interface to all of them.
    You can change the sidelights to match the Xenons more closely, although they're not perfect. I've done this on my car by fitting Philips Blue Vision sidelight bulbs. They're about a fiver delivered from eBay. Note that blue LEDs will work but will show a bulb failure warning on DIS, thanks to their lower wattage.
    Hope this helps!
    2004 A3 Sportback 2.0TDI SE, RNS-E Sat Nav SW0650 TMC, 17" Star Alloys, Xenons, DIS, Rear Mats & Sunblind, Alu trim, Ebony Black pearlescent
    2006 Honda Accord EX i-CTDI, Arctic Blue, Leather, Sat Nav, XCarLink
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    But you can fit LED bulbs without having any problems, PIAA do some and they're the same W.
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    RNS-D does show a compass on a separate screen, press the right knob when on the map screen and it will appear!
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
