Sky InsuranceChris Nott
Results 1 to 12 of 12
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,439
    Exclamation One for Electricians!
    OK, I seem to have a wiring problem in the house, it seems that 9 times out of 10 times, when I switch a light on in the house and it decides to blow with a bright flicker and a quick pop, it also takes a fuse from the main fuse box with it, so i have to go into the garage to flick the switch. I've never had this problem in my previous house, so does this sound normal?
    And the main reason for this post is the light I have at the top of the stairs from the landing is constantly flickering, it's on a dual circuit(not sure of the correct term?) where you can switch it on and off from either upstairs or downstairs, you guys know what i mean! But there seems to be some sort of current going through at a slow rate(when switched off) which causes the bulb to flicker every 5 secs or so, and reduces the lightbulbs life to one a month!, so i'm using an energy saver now which has lasted 6 months, but even that one flickers every 10 secs or so.... anyone got any ideas on this one?
    I've been a bit suspect about the wiring in the home for sometime now, is it worth getting in an electrician to give it a once over for peace of mind? and anyone recommend any specialists/electricians in the Solihull area?
    Thanks.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Hi Jo,
    When you say 'fuse' - do you mean a fuse, or a trip switch. A fuse will need a new piece of wire, a trip switch just means you flip the switch back on.
    I'm not a qualified electrician, but I've rewired a kitchen and fitted a new ring main in the loft of my house. If it is a trip switch, then I'd say then it is doing its job by tripping out the electricity when the bulb pops. It is exactly the same in my place if a filament bulb pops. Fortunately most of my lighting is either low voltage halogen, or energy savers which don't cause a trip out.
    Think of it this way - if you are cutting the grass and mow through the cable, you want the power to turn off. This is just the same thing, but applied to a lighting circuit.
    In terms of a flickering bulb, sounds like a loose connection somewhere. Should only take a few minutes to turn the electricity off (the main switch that turns everything off, don't try to just isolate a single circuit), take off the switch plates in the hall and landing and check the connections, and ditto in the ceiling rose. I'd say it is probably a faulty switch.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,439
    Yes, trip switch mate, I'm not with it today lol
    The trip switches never flip in the old house I was living in, when a bulb went, so I was wondering if it's normal for it todo so in my current house? Seems the norm from your reply though.
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    Sounds like you have a problem, it could be something as simple as a faulty lightswitch or could be something incorectly wired. I would sugest changing the lightswitches and if this makes no difference then really you need to get an electrician in
    99 S3 Absolute red
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Quote Originally Posted by jojo
    Yeah, from my experience. I've lived in three houses with trip switches and they've all tripped off when a filament bulb has blown on a lighting circuit.
    Jason
    Mo-S3's Avatar
    North West
    706
    Mine trip too when any bulb blows in the house. I'd say a small price to pay for piece of mind.
    Get the wiring checked on both the switches and the light fitting itself.
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    I served my time as an electrician, If you do change the switches take note of the wiring when you do it.
    It could be a loose connection in the ceilng rose, or in the back of the switches, but yes the MCB (miniture circuit breaker) will trip when the lamp blows as it sees it as a fault due to current flow differential.
    Check the connections in the ceiling rose and the switches fella but be careful!! and isolate before you open any cover.
    any more probs PM me fella
    chris
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Sounds expensive Joe, maybe a full re-wire.
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,439
    Thumbs down
    Quote Originally Posted by TDI-line
    That was just the answer I was looking for Dan - Thanks
    marmite's Avatar
    Counting the Tesco Club points
    Jul 2006
    Barnet
    1,070
    Hi Jojo
    RCD circuit breakers are great but can also be areal pain in the arse, really depends on how sensitive they are..Ours always blows when a bulb goes and if it a Halogen bulb it trips the whole board so we got to reset everything in the house.
    I would do they same as above check conection and maybe replace some bulbs..I found cheap bulbs constantly blow so now use osram bulbs(halogen) in my kitchen and bathroom and never had a problem since
    Good luck buddy
    Audi RS6 Daytona GreyLoving all 455.7BHP of her
    dgannon69's Avatar
    Jul 2005
    Worcester, England
    465
    Is it an old house mate? could be Casper the friendly Ghost??
    1.8T A3 --- AmD RR @ 195bhp, 18" Pollished RS4's
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,439
    Quote Originally Posted by marmite
    Good luck buddy
    Cheap bulbs! I use cheapo Tesco bulbs, could be the reason huh?
    Think I will check the switches to fix the blinking problem.
