Volks AutosChris Nott
Results 1 to 8 of 8
    C_Audiboy's Avatar
    Vroom Vroom
    Nov 2004
    Glasgow
    811
    4 cylinder 20V engines - why no more???
    I was just wondering why Audi (VAG more to the point) seem to have dropped the 5V per cylinder configuration on the new 4 cylinder engines?
    I'd have assumed that it was 5V for a good technical reason and I assumed it to be an improvement over 4v per cyl. But we are now back to 4V per cylinder in the new 16V FSI units.
    Anyone know the reasons behind this?
    I don't claim to know **** about how engines work....... I'm just curious!!!
    987 Boxster 2.7 (05) - Current
    A3 2.0T Quattro S-Line (55) - gone
    S3 Quattro (02) - gone
    icenutter's Avatar
    Jun 2006
    595
    They probably found that the benefits didn't outweigh the costs (weight and money). You can get away with any old rubbish if you are turbocharging an engine
    smitch's Avatar
    Sep 2006
    1,585
    Dunno, but i used to have a 90 20V which was 5 cylinder with 4 valves per cylinder and wondered why they went to 4 cylinder with 5 valves per cylinder!?!?!?!
    S4.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    I seem to recall that in order to get the FSI injector into the head, there wasn't room for all 5 valves...so they reverted to 4 valve heads, plus a direct injector and a central single spark plug.
    At least I think that's the reason...
    BYW...this 5 valves are better than 4 is bull**** anyway...on a road engine with properly designed heads, there is no reason why a 5v flows more than a 4v...so don't go looking at it as a backward step, 'cos it isn't.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    Beerzo's Avatar
    Masa'warty 3200... Talk To Me!
    Feb 2006
    Scotland
    1,241
    Yup plus the valves maybe bigger now, so they may not have needed the 5.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    The inlet valves will be larger...they were pretty small on the 5v heads.
    Please note:
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    5 valves per head is no better than 4 if the 4 are designed properly. The use of turbos on a lot of cars now also negates the need for the extra valve.
    Also the extra engineering needed has clearly been dropped as it offers no more in the way of performance or economy.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    And there's me thinking there might have been a shortage of valves...
    Justin
    2001 VW Golf 2.3 V5 (170) Highline, Indigo Blue - standard, for now...
    A4 (B5) SE with a few slight amendments here and there (sold)
