Volks AutosAH Fabrications
Results 1 to 10 of 10
    Defratos's Avatar
    You’re Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Question Need help with power tool
    Ok so I bought an impact wrench a few days ago, details are as follows:
    Ingersoll Rand 2530KE Cordless 1/2" impact wrench
    Max torque of 350 Ft-lbs / 475 Nm.
    Speed 0-1,650 RPM
    http://www.irtools.com/IS/product.asp-en-2868
    Right now the reason I need help is because I tried it out yesterday on my S3 and it wouldn't take the bolts out. Now I never bought a Deep impact socket for wheels, I just have some 1/2" bolts lying about that are the same size of the bolts on my wheels, but the wrench would just cycle through (as if the bolts too strong). So what I wanna ask is is 350ft-lbs enough to take out bolts? and do I need a specific wheel socket set or something? not sure if this makes too much sense but I'd appreciate any help
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    Oct 2006
    246
    A lot of tyree fitting companies use these now to undo/do up wheel bolts (and then torque them up), so I'd expect it to be up to the job.
    Daft question but was the battery fully charged?? The tyre fitters my company uses has them. The fitter presses the trigger, the wrench winds up internlly before releasing inside to 'crack' the nut/bolt. It some times takes 2 or 3 goes to get the bolt loose, but has always worked.
    Defratos's Avatar
    May 2004
    2,230
    humm, maybe I have to hold the trigger for longer, roughly how long would you say it winds up internally? and does it make a noise while winding up? and yeah the batter was fully charged, I'll have another go and see what happens
    Audi S3-BAM
    Oct 2006
    246
    The one Iv'e seen used winds up internally (gaining inertia I presume) and then there is a sharp crack noise as (what I presume) is the gearbox engaging and turning the socket and in turn undoing the bolt.
    It isn't like a corless screwdriver where the socket turns the minute you press the trigger. I assume there is a centrifugal switch mechanism inside that engages at certain rpm.
    Hope that makes sense!!!
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    The first thing i would ask is how tight are the bolts ........have you tried takening one off to see how tight they are with bar?..as could of been put on with windy gun at tyre fitters
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    Onlyme's Avatar
    Oct 2006
    593
    I have a cheap halfords one of those drill things that you use from cigarette lighter socket, didnt work at first so took the wheels off and copper sliped the nuts and now have no probs
    Defratos's Avatar
    May 2004
    2,230
    Yeah I've tried taking the nuts out by hand and they're tight but I would expect a 350 ft-lbs power tool to work on it. What exactly does copper slipping do? and what is it?
    Audi S3-BAM
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    I used to be a car mechanic and I had a compressed air impact wrench, it never wound up, just went bang bang bang as it went round and as each bang happened it shocks the nut up tighter.
    Wheel nuts should be nowhere near 350 foot pounds, a cylinder head normally only goes to about 160!
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Defratos's Avatar
    May 2004
    2,230
    Quote Originally Posted by A4Quattro
    Thanks for the help, just wanted to ask does it also go bang bang bang sometimes when taking out the wheelnuts?
    Audi S3-BAM
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    same in either direction, but it will impact until the nut is loose enough to just spin undone.
    Chris
    See my images @
