Volks AutosBadger5
Results 1 to 11 of 11
Thread: A Gas Question
    necroeire's Avatar
    Feb 2004
    Ireland
    1,003
    A Gas Question
    Will a cylinder full of Oxygen weigh the same at 20DegC than at 70DegC?
    B6 A4 1.9TDi 130Bhp, 18" RS6 Reps, iPod ICELink, S4 Grill, S4 Door Flares
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    This is probably worth checking as my recollections are hazy; and I guess it depends on exactly what tolerances you need to be working to (as I'm sure there is a "small" effect); but AFAIK the volume of the gas may change (because the density changes with temperature), but it's mass shouldn't (apart from that hair-splitting margin)...
    Regards,
    Rob.
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    And i thought this was about central heating again.
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,566
    Is this one of those Aeroplane vs Conveyor belt threads?
    tonedef's Avatar
    Mar 2006
    Chesterfield
    147
    Quote Originally Posted by necroeire
    Of course it will, it'll just be harder to carry?
    2001 S3|Ebony Black|Revo|MTM Clutch|RS4 Reps|Tarox Brakes
    '95 Corrado VR6|Classic Green|Koni/Eibach|Undergoing major rebuild!
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    And a little hotter.
    enda1's Avatar
    Jan 2006
    Ireland
    439
    Do you mean a cylinder of compressed oxygen as in a cylinder for an oxyacetelyne torch. If so then the weight will be the same as the mass of the gas has not changed its just that the internal pressure on the cylinder wall will be higher as the the gas at 70C has more energy and as such is at a higher pressure
    This is explained by the compined gas law shown below.
    P1 V1 / T1 = P2 V2 / T2
    P= pressure , V =volume and T =temperature in kelvin
    In this case the volume is constant as the cylinder does not change.
    Solving this we get the Pressure at 70C (343Kelvin) = 1.17 x pressure at 20C(293)
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    necroeire's Avatar
    Feb 2004
    Ireland
    1,003
    That's what I thought but, I was told by an expert from the gas company I'm building a system for....if the cylinder has 20% liguid O2 and 80% compressed O2 and the temperature increases - reducing the pressure by producing more gas, then there will be less liquid oxygen and more gaseous oxygen thus having a lower weight. The total mass will remain the same but the weight will decrease. I still don't understand this explaination but I'm sure he is right.
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    weight is a function of mass , only thing that will change weight would be a change in gravity.
    just a little a6
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    I think I could see his logic if the gas / liquid was changing state, but I don't see how it can between those temps as it's boiling point is -180 degrees and even then I don't think it matters. I think it's mass and therefore weight would be constant all other things staying the same except temp.
    Yeee-haw
    Jason's Pong Champion
    Dec 2005
    Houston
    528
    No change, it's a closed system. Nothing gets in, nothing gets out. Phase changes don't alter mass.
    Mike
    Last edited by Geordie Mike; 2nd October 2006 at 18:15. Reason: Missing one small but crucial word
