EM TuningAH Fabrications
Page 11 of 13 FirstFirst ... 45678910111213 LastLast
Results 401 to 440 of 494
  1. #401
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,852
    Quote Originally Posted by A4Andy
    Christ.
    It will not take off. Thrust has no relevance in this equation.
    Airflow over the wing causes an area of low pressure above the wing, the wings shape facilitates this. The area under the wing has normal pressure so the wing is sucked up into the low pressure.
    Engines on a plane are used to propel it forward through the air, forcing air over the wings and creating the aforementioned areas of low pressure.
    If there is not enough airflow over the wing the pressure variance is not great enough to sustain lift and the craft enters into a stall; this has nothing to do with stalling the engines.
    So, regardless of ground speed if there is no flow over the wing there is not lift and it cannot take off.
    How can you be sure it won't take off? Have you tried it??
    You've got to have a laugh!
  3. #402
    Beerzo's Avatar
    Masa'warty 3200... Talk To Me!
    Feb 2006
    Scotland
    1,241
    Hey just had an idea - Brainiac on sky one!
    The "I can do science me" bit.
    I think someone should type up a letter and have everyone digitally sign it from all the forums that this post has went on. Then see if we can try it out for real.
    I would have suggested MythBusters of the Discovery Channel but that guys tash is wrong and they are far to camp for me. Science'y things should be manly and braw!
  4. #403
    A4Andy's Avatar
    Quattro-tastic. Not half.
    Jun 2006
    Glasgow - Southside
    459
    Quote Originally Posted by jojo
    I don' have to, I know it wouldn't take off.
    http://www.allstar.fiu.edu/AERO/princ1.htm
    Andy - A4
  5. #404
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,852
    You state in your previous post that thrust has no relevance, but in the original question, it suggests that when the plan fires up it's engines, the plane moves forwards, which I would presume is some sort of thrust - correct?
    Now if the plane is moving, there's obviously some sort of airflow going over the wings, how fast will it be moving is another question of course... the confusing bit is the conveyor belt applying opposite force to prevent the plane from moving, so friction is the only force stoping movement, but we all know most planes free wheel, so whats stopping the plane from taking off??
    Just my theory of course
  6. #405
    A4Andy's Avatar
    Jun 2006
    Glasgow - Southside
    459
    The aircrafts wings are no moving through air so no air is flowing over them.
    The fact that the plane's wheels are moving due to forward thrust is irrelevant. Wheels on a plane are simply there to reduce the amount of friction an aircraft must overcome to gain forward motion. The forward motion is required to get air passing over the aerofoils (wings).
    Newton's First Law of Motion applies. The thrust in this case is negated by the treadmill effect of the runway. Equilibrium is reached and there is no forward motion over all.
    The fact remains no air is passing over the wings means there is no change in air density or pressure and therefore no lift is created.
    Andy - A4
  7. #406
    Just Plain Old's Avatar
    Jun 2004
    Warwickshire
    1,257
    Andy, you're getting all confused mate. As I've said earlier, the answer is that a converor belt runway is not 'capable' of preventing the thrust of the engines moving the plane moving forward and thus producing the required lift!
    In my personal opinion
  8. #407
    A4Andy's Avatar
    Jun 2006
    Glasgow - Southside
    459
    Engines do not provide lift unless they have a combined thrust to weight ratio of greater than 1:1. So that's enough lift to move the combined weight of the engine/s and aircraft as a whole. Even then it would have to be stood on its arse and point nose to the sky; vertical.
    In the horizontal engines, no matter how powerfull, do not create lift. No lift, no flight.
    Andy - A4
  9. #408
    A4Andy's Avatar
    Jun 2006
    Glasgow - Southside
    459
    Quote Originally Posted by Just Plain Old
    Don't make me start quoting Relativity.
    Andy - A4
  10. #409
    Jun 2004
    Warwickshire
    1,257
    errrrr........ it's a trick question, but a more detailed explanation is among these pages. The plane would take off!!
    I don't know where the smilies are, otherwise I'd do a big grin.
  11. #410
    A4Andy's Avatar
    Jun 2006
    Glasgow - Southside
    459
    Ok, you're sstanding at the side of the runway watching this, i.e. you're not part of the conveyer belt system. Is the aircraft moving relative to you?
    Andy - A4
  12. #411
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,852
    I'm with JPO on this one, re-read the question Andy, it is suggested that the plane is in motion when the engine fires up! so yes, the aircraft will be moving if we were to be standing on the side of the runway watching it.
  13. #412
    A4Andy's Avatar
    Jun 2006
    Glasgow - Southside
    459
    What's the point in the treadmill/conveyor then?
    Andy - A4
  14. #413
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,852
    Thats the trick bit, it's not actually a trick question as such, more of a 'it wouldn't actually work in the real world' type question.
    Some have said the wheels and conveyor belt would go straight to infinity if the plane was to move an inch, but I'm no expert in that field, I'm just stating facts.
  15. #414
    bainsyboy
    Im really not bothered Einstein, as all i know is that if i had been sat on this plane for months now waiting for it to take off i would have caused a riot trying to get off of it by now and asked for a refund
  16. #415
    Jun 2004
    Warwickshire
    1,257
    The 'trick' I guess is that the question infers that the converor belt would be capable of preventing the forward motion of the plane, when in reality it couldn't. But if it could then yes, the plane would not move forward and thus no lift, no take off!
  17. #416
    OutLore's Avatar
    VOIP Dude
    Oct 2003
    Essex, UK
    1,183
    OK I think I have solved it once and for all.
    What would happen if the plane were to land on the belt?
    Would it just stop dead and the wheels spin? HELL NO!
    Spence
    ________________________________________
    Now: 2011 A4 Avant 2.0TDi Black Edition Multitronic Aruba Blue
    Gone at 77k: 2008 A4 Saloon 2.0TDi 140 S-Line Quartz Grey
    Gone at 80k: 2007 A3 Sportback 2.0T S-Line S-Tronic Mauritius Blue
    (4 S-Tronic boxes, 3 Mechatronics Units, 2 Dual Mass flywheels, 2 sets of engine mounts)
    Gone at 32k: 2005 A3 Sportback 2.0TDi 140 S-Line DSG
    Ebony Black
  18. #417
    NEiLS3LK51's Avatar
    Jul 2004
    West London
    188
    In reality the belt does counter the forward movement of the plane, it moves nowhere. I promise to post the video of this experiment next week.
  19. #418
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    therefore the plan is phsyically static with only wheels moving and therfore no wind mass movment over and around wings for lift. as i said b4, ha!
    Vehicle wrapping specialist
    NOW SOLD S6 Avant 4.2 V8....ooooo the noise hehe
    NOW SOLD '03 A3 TDi Quatty Sport Mods so far: Aerowipers front & Rear, Type R Sting ariel, 18" RS-TT Alloys, Superchips remap, Eibach Pro Springs -40mm, Bilstein B8 dampers, R32 ARB's Front & Rear, Pipercross panel filter
  20. #419
    Jun 2004
    Warwickshire
    1,257
    I think I'm going to commit mass murder...............
  21. #420
    griffj's Avatar
    Oct 2005
    chester, cheshire
    105
    Talking
    good god is this still going!!
    if my cat walks all over my avant one more time!!!!!
    2002 51 A4 Avant in amulet red. full leather in cream, s-line front spoiler....and much more to follow!!
    2004 passat estate, full leather with 18" rs4s 30mm drop badgeless grill..us spec bumpers
  22. #421
    A4Andy's Avatar
    Jun 2006
    Glasgow - Southside
    459
    The aircraft would inch forward, however if the conveyor moves to compensate any forward motion of the aircraft then equilibrium is reached; a rolling road situation (without the tethers).
    As previously stated wheels on an aircraft are only there to minimise the amount of friction the craft must over come to gain forward motion and start air passing over the wing.
    Netwon: An object will remain at rest or in uniform motion in a straight line unless acted upon by an external force.
    If the forward motion of the wheels is negated by the action of the conveyer belt moving in the other direction at an equivalent rate, the net result is that the body of the craft remains stationary to an observer standing at the side of the runway/conveyor.
    Velocity:
    Lift
    Since the aircaft has no velocity in relation to it's surroudings, excluding the runway/conveyor, then the net velocity is zero.
    If the value of zero is entered into to lift equation then L = 0, regardless of anyother values.
    Andy - A4
  23. #422
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,852
    LOL at all the technical stuff, the aircraft I would have presume would have had jet engines to provide the thrust to move it forwards, so apply full thrust and afterburners or whatever... we should now have a moving plane right? Unless the tyres are stuck to the conveyor belt with superglue4, the conveyor belt is as stiff as solid concrete and all the wheel bearings on the jet are seized, my thoughts is that the aircraft will move and take off!
    Unless you are saying that a conveyor belt has the ability to negate any thrust created by the jet engines?!
  24. #423
    A4Andy's Avatar
    Jun 2006
    Glasgow - Southside
    459
    The aircraft is moving, but only relevant to the runway; not the extended environment around it.
    What stops you running off a treadmill and through the wall? Is it the fact that the tread is moving in the opposite direction to your feet which are propelling you forward? You are moving forward, but only relevant to the tread, not to your extended surroundings. You will not feel wind on your face no matter how much you run on a treadmill. The same principle applies to the aircraft.
    Another example, you return from the toilets in a train. The bog is at the head of the train which is travelling at 100Mph. You walk at a pace of 3Mph.
    Now, the train you’re on is moving in this direction: --->
    You are walking in this direction: <---
    How fast are you travelling?
    To you and your fellow passengers you are only moving at 3Mph in this direction: <---
    However, to someone watching from a platform you personally, not the train, would be travelling at 97Mph in this direction: --->
    Andy - A4
  25. #424
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,852
    Now, the train youre on is moving in this direction: --->
    I get what you are saying Andy, with the treadmill example, but the engines on the aircraft are more than likely to be jet engines, which provide thrust to push the aircraft forwards. Surely you can't have an aircraft at maximum thrust sitting still with a conveyor belt going at 500mph+ to counter act the force?
  26. #425
    A4Andy's Avatar
    Jun 2006
    Glasgow - Southside
    459
    So now you're placing limitation on the conveyor? Isn't that moving the goalposts?
    It's like arguing if you put Thrust SSC in a rollingroad could it move forward. Essentially your asking the same thing. The answer is no, it wouldn't.
    In pure physics the aircraft will not take off.
    Andy - A4
  27. #426
    Jun 2004
    Warwickshire
    1,257
    Groooooooan........ Andy, unlike a car an aircraft is not driven by its wheels, that is the critical factor! when an aircraft takes off and it's wheels leave the ground it doesn't stop moving forward does it? Hope that helps!
  28. #427
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Quote Originally Posted by Beerzo
    lol i said do the brainiac bit as well
    ~ ~ ~2003 Audi S3 BAM ~ Ming Blue ~ 18" BBS Alloys ~ Heated Black Leather ~ Forge DV ~ RNS-E ~ denison ipod link~ parrot mk6100 bluetooth ~ ~ ~
    Still need Remap
    2007 Audi S3 8L
    2005 Audi A3 1.6 sport grey with climate control
    2003 Audi A3 1.6 sport black without climate contol
  29. #428
    A4Andy's Avatar
    Jun 2006
    Glasgow - Southside
    459
    Take some secondary school Physics lessons and come back to me once you have a grip of Newton's Laws of Motion.
    I'm done with this thread.
    Andy - A4
  30. #429
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,852
    Andy, I find it disappointing that you had to post that pic and be done with the thread, we was just getting started lol.
    Anyways, your problem lies with you thinking as a physician(sp?), and applying physics to the question, of course the numbers don't add up? Think outside the box, the engines pushes the aircraft forwards, the wheels just holds it up! The conveyor belt can do what it likes, but it shouldn't(theoretically) effect the aircrafts forward movement.
    All in my opinion of course, those who agree with me say aiy.
  31. #430
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    aiy :P
    red to red black to black blue to bits
  32. #431
    scoTTy's Avatar
    Essex, UK
    1,957
    A4Andy knew he fecked up so did a runner. Shame he didn't read and consider the earlier posts.
    I love people who reckon they know it all, insult other people and then go off and sulk. The web wouldn't be the same without them. :D
    MY2010 B8 A4 Avant 2.0TFSI quattro S-line Executive
    Honda CBR1100XX Super Blackbird
    Gone : B6 S4 (AMD stage 3), TT (APR), Golf GTi, CBR600F
  33. #432
    NEiLS3LK51's Avatar
    Jul 2004
    West London
    188
    Thrust SSC WOULD move forwards on a rolling road because unlike the conveyer belt system the rollers are not powered in the opposite direction, hence do not apply enough negative lateral acceleration to hold it in place. (Just a small amount of drag due to the friction of the tyres driving the rollers round)
  34. #433
    bainsyboy
    Quote Originally Posted by scoTTy
    IM STILL HERE AND STILL NOT BOTHERED ( smiley face thing but its fo--ing gone )
  35. #434
    bainsyboy
    On a serious note i found A4andys picture highly offensive and rather sick
  36. #435
    scoTTy's Avatar
    Essex, UK
    1,957
    Agreed. That picture often gets pulled from forums for being offensive. The posters are normally twats.
  37. #436
    Nov 2005
    lothian
    179
    no a conveybelt used in placeof a runway wouldnt work to launch planes, but that isn't the purpose of the question, if the conveyor belt was 2 miles long the plane would simply take off as normal with the exception of the astronimical extra speed of the wheels......
    This is all ignoring that fact thers no way a conveyor belt would keep up with the astronomiacal rate of the the wheel speed increase.....
    Think about it
    plane speed....0 wheel speed 0
    thrust from engine move plane forward regardless of the wheel speed
    plane speed 5mph Wheel speed 10
    Plane speed still 5mph wheels already doing 10 so trying to compensate for the continued 5pmh forward motion extra 5mph means wheels are doing anther 10 mph increase meaning wheels speed now 20mph and so on and so forth, so even is the plane continues doing any speed at all, the conveyer belt will feedback on itself and explode! Even if the conveyor belt could do that the wheel bearing would go out with their rated speed and cease causing the plane to be force backwards probably ripping the indercarriage off. :o)
    So realistically yes the plane will probably take off because the caonyayer belt coulne keep up anyway..... But hypothetically the wheels would cease and it would all go pete tong.......
  38. #437
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,883
    Oh no, i've loaded the gun again. :D
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
  39. #438
    Nov 2005
    lothian
    179
    Bang...... This isnt what I planned to do today... lol
  40. #439
    Nov 2005
    lothian
    179
    yep..... But.... the slower the planes acceleration and the higher the take off speed the higher the wheels rate of accerleration(cos of the belt) and ultimately final wheel speed..... Everyon follow that lol
    a plane wheel doing 600 mph will probably be well over the wheel bearing rated working capability.......lol.....
    thus seizing and destroying the wheel and sending the plane skidding along the conveyer belt at a relative speed of 600mph until the belt realises there is no wheel speed anymore stops dead and then the planes only skidding along at it s real speed........ probably sideways at that point,... possibly in a roll ripping the wings off and fuselage apart...... very pretty...
    must be a hell of a ride....
  41. #440
    bainsyboy
    Cant we lock this thread to stop people bringing it back to life.
