[ QUOTE ]
its to do with type of the breaking equipment that will allow you to make use of the bigger discs, like porsche callipers with pistons on either side will offer better biting character on the disc
[/ QUOTE ]
Not true.
Pad choice dictates this far more than massice callipers and huge discs.
Massive Porsche callipers can offer LESS biting feel, and a much longer pedal push to get the brakes on - back to piston sizes vs master cylinder size again...
An OEM set of brakes with decent pads and some disc cooling can work just as well as the bling alternative, I proved that for long enough with my S3.
...and you keep the pedal feel, which, to me, is very important.
[ QUOTE ]
where oem audi ones have pistons on one side pressure on the disc is uneven this causes the brakes to look up
[/ QUOTE ]
Again, not so...
If the brakes are well maintained, they work just fine.
An example:
My Integra Type-R had standard callipers, grooves machined into standard discs and mintex pads...there was nothing that would outbrake one of those things on the track...and I did 20+ trackdays on the same disc/pad/calliper combination.
They worked faultlessly...
No need fo 4 pot callipers there...
Bolting on big brakes is not the complete answer that many believe it to be.
They look better...
But often make the car less nice to drive at 7 - 9ths.
[ QUOTE ]
audi oem brakes are very poorly designed limiting effective disc size.
[/ QUOTE ]
Again, not true.
OEM brakes are fine.
I have OEM S3 brakes on my Golf GTI and they are perfectly fine...
The standard pad material is awful, and there is not enough air getting into the discs to cool them...rectify these and these brakes are fine.
I have never been left lacking...nor had them fade.
And I don't pussyfoot about with my brakes.
[ QUOTE ]
many posts on here comparing the two , i talk of experience going from stock 2 piston floating caliper audi two 6 piston cayenne 3 piston each side difference is amazing car suddenly stops like it should of,
[/ QUOTE ]
...and my experience of many of these kits is that they look great...but make the pedal feel awful and don't offer the gain I'd expect.
They offer a gain...sure.
But how much of that is down to them replacing old and partially siezed standard stuff?
Also, nobody considers what bolting on 350mm x 30mm discs and massive callipers is doing to the handling? Killing it...that's what...
Or the brake balance...
Or the pedal feel...does nobody else heel-and-toe? Try that with a pedal you have to push into the carpet to get the discs and pads to meet...
