Sky InsuranceBadger5
Results 1 to 7 of 7
    Southampton
    159
    Tv installation...
    Hi, we have a problem tuning in a tv in an upstairs bedroom! We're in a new build house. I put an aerial in the loft and tuned in the tv down stairs no problem. Now, two bedrooms upstairs have aerial connections fixed into the wall, but if i connect a tv upstairs it wont tune in as there is no signal?! When we moved in there were two co-axial leads in the loft, i hooked one up to an aerial and the downstairs tv tuned in fine, but why does'nt a tv tune in upstairs plugged in to the built in aerial socket?!
    Hope this makes sense and help!!
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    You need to get some sort of a splitter (and probably worth getting one with a built in signal booster/amplifier as well although you'll need power to run it which may be tricky in the loft) so that you can plug the aerial you fitted into it and then split the signal 3 ways - one for your lounge, and one each for the two bedroom sockets.
    I have a similar setup in my house, 1 aerial feeding a 4 way amplified splitter which puts signals into the lounge, kitchen and 2 bedrooms.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    :: blade ::'s Avatar
    Sep 2013
    preston
    196
    Visit :: blade ::'s Youtube Channel
    you need a splitter and connect the other coax up
    Southampton
    159
    Thanks for the reply^^. Not sure if im being clear though! Tv is tuned in fine down stairs, but when trying to tune in a tv to the ready fitted aerial socket upstairs, the tv wont tune....... Why?!!!!!!!
    A4B8Sline's Avatar
    Jan 2012
    Exeter, Devon
    169
    You will have a co ax cable for each tv outlet. You need to take one from your aerial to a splitter preferably boosted. Then connect all your co ax cables in the splitter. Each tv point in a new build will be wired back to the loft individually.
    Hope this helps. (Elec engineer )
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,532
    Quote Originally Posted by Jp-tqs View Post
    No signal.
    Sep 2013
    preston
    196
    in new builds they only connect the coax in the rooms to the faceplates, not in the loft, so the 2 coax in the loft one is for the bedroom and the other for the lounge, get the one that isnt connected put onto a 2way splitter (with there only being 2 coax you wont need a powered amplifier) so long your signal is good and all your connctions are spot on.
  1. getting and installing sat nav
    By sash in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th October 2003, 11:45
  2. Installing a subwoofer in a 2000 a4
    By anastasia248 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th September 2003, 00:49
  3. Help Installing Kenwood music Keg cable
    By phillj in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2003, 07:35
  4. A4 AVANT INSTALL
    By AndyC in forum In-Car Entertainment
    Last Post: 29th July 2003, 13:33
  5. big headache on a3 ice install
    By dsiewuk in forum In-Car Entertainment
    Last Post: 28th June 2003, 17:26
