EM TuningSky Insurance
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By pablo
Thread: Seat Leon tdi temp gauge fault
    lewis.bates.73's Avatar
    Sep 2013
    33
    Before we start i know this is an audi forum but it has the same engine as my audi just need some advice please
    Hi there I have just brought a seat Leon 1.9 tdi 110 and I've noticed it gets up to temperature then it drops down then back up ? I wanted to know if anyone could tell me what might be causing this ? And will this fault be stopping my fans from coming on or not ? Thanks
    Lewis
    May 2012
    RETFORD, NOTTS
    1,748
    First i would test the temp readings wth an external gauge or vcds. if the display reads wrong could be the temp sender or clocks. if clocks are suspect check the earths around the ecu and battery.
    Do the other needles do the same?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Sep 2013
    33
    Quote Originally Posted by @udi A3 View Post
    No it's just the temp one that's it been told could be coolant temp sensor if it is would it effect my fans coming on
    May 2012
    RETFORD, NOTTS
    1,748
    possibly but doubtfull, the temp switch in the radiator should control the high and low fan speeds. iirc that CTS is just ecu and dash info.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    816
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    More than likely it will be the CTS. VAG use 4-pin sensors on most vehicles, 2 pins for the ECU and 2 pins for the temperature gauge. You may get reduced fuel economy if the ECU side is faulty.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    Aug 2006
    NI
    785
    if it drops on a fast light load run (eg cruising on motorway) then comes back up in traffic it will be the stat stuck open imo.
    jojo likes this.
    back to boost, oh how I missed thee....
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,411
    Quote Originally Posted by pablo View Post
    I'd go with this.
    You've got to have a laugh!
    Sep 2013
    33
    Thanks guys much appreciated i willl do some more digging
  1. W ( 2000) A3 tdi temp gauge problems
    By arryboy93 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2013, 15:54
  2. Just got my 2001 A3 - fuel & temp gauge fault.
    By Ay3 in forum General Technical / How To
    Last Post: 12th May 2011, 13:44
  3. Audi A3 dash temp gauge fault
    By r3ahj in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2011, 23:23
  4. b5 tdi fuel gauge fault
    By slats0356 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th August 2010, 13:33
  5. TDi temp gauge
    By mayurw in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2007, 18:00
