JMB RetrofitsEM Tuning
    May 2013
    25
    Audi a3 battery drained ---traced it down to faulty RhS headlight
    Hi.so basically bought ab audi a3 and decided to make few touches upgrades etc.started with alloys wheels ad coilovers.then i decided to go ahead and get HID kit in,after fitted hid decides to buy myself led sidelights.and neer even noticed that they were not can bus friendly.after few days of instaliation rhs sidelight stoped working.there was no power what so ever.so didnt do much just got a dodgy install diy job got cable from lh to rh sdelight bulbs were connected inseries.then after few weeks my battery went flat(-"after 3 days unused car) i got it jumpstarted and my gf went away to work.started fine afterwork got home and left the car sitting for about 12hours -battery flat!!so i lend a charger and and gave my battery 4hr charge as battery level(charge) wee light were black...afterwards fitted battery and noticed my hazard light iluminated all time.same as my rear mirror light and small wee switch beside light turn switch(like a dash ligh swich) and they were on all time untill nezt day i bk home.took my muktimeter and dis out 1a drainage which led to 0.5 in a minute..and then dropped till 0.42 after five minutes...ive start to go thru my fuses and took RHS light fuse---voila it went to 0.2 as its normal(ecu and memory) so ive half way done thru my trip now to fix my fault.so gona keep updated.tho i will share my expierence
    mayve any one has any suggestio s-thank u guys!!
    May 2013
    25
    So,i came back home and had few mins spare time,ive unluged my after market HID kit and drainage was the same,sits 0.4 all time,then i took both fuses out and the drainage went down to 0.16
    so i noticed my both sidelights work fine BUT only for 2-4seconds,could that cause CAN BUS NON FRIENDLY LED (quad) bulbs? or there is somewhere a fault?what do yous think?any suggestions at all>?
    0.4 isnt a massive drainage but a drainage non the less!
    car starts ok so far(touch wood)if used daily
  1. audi a3 diesel 1.9 1999 model battery drain
    By phill147 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2011, 23:17
  2. Please help (strange battery drain)
    By mrlinderley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th March 2009, 20:12
  3. A4 Battery drain-help
    By audimike in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd December 2008, 07:24
  4. coupe battery drain
    By andy64 in forum Classic Audi Forum
    Last Post: 13th February 2006, 12:43
  5. Battery drains out in a day.
    By mashoud in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th November 2004, 07:36
