Sky InsuranceVolks Autos
    Apr 2013
    Aberdeenshire
    592
    Hot water cylinder help
    Hi I am looking to install an unvented water cylinder and do away with my 140lt vented set up however I only have 1.5 bar mains pressure I quite like the valliant units or 180lt indirect cylinder however I am concerned that my low water pressure will give me a poor mixer shower performance would any plumbers be able to advise ?
    cheers
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,003
    Use a boost pump for the shower.
    JSD 2.59
    Synergy-Solutions
    Apr 2013
    Aberdeenshire
    592
    Do you mean keep the vented set up and use a twin impeller pump for the shower or use a boost pump on the unvented side like a salamander home boost the problem I have is that my header tank in the loft is only 25 gallons most if not all the pumps I have seen need 50 gal of usable head.
  1. misfiring in 3rd cylinder, help please
    By xCoupexAshx in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2012, 20:29
  2. No hot water getting into the heating system? What can it be
    By DJM1982 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th December 2010, 18:09
  3. A4 Cabriolet Water Leak - Help needed
    By MFoley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th August 2010, 20:00
  4. Hot Water Blast 2010
    By cort in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2010, 18:00
  5. Cambelt/water pump help needed
    By Fishy_bob in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2009, 21:44
