Volks AutosEM Tuning
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By ScottD3
Thread: cutting foam
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    cutting foam
    I need to cut up some foam pads for my boot but want to get a better finish than last time.
    Anyone know the best way to cut foam, mainly shapes?
    I used a sharp knife last time and it did ok but not as neat as I wanted it to be.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    Hot wire? Not sure it'd work for foam, but works for polystyrene.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by crazy88 View Post
    I did think of that.
    Even a soldering iron with a thin nib.
    dantdi's Avatar
    Feb 2008
    kent
    511
    How thick is the foam you are try to cut?
    Don't suppose you have access to band saw do you? Get a nice clean cut.
    Sharp knife normally works alright. Try spraying knife blade with silicone lubricant that helps lot.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    I'm redoing this.
    crazy88's Avatar
    West Yorkshire
    4,806
    Ah yes, the murderer drawer! Gone are the old days of handcuffs and a rag. Scott needs a spanner nowadays.
    So are you wanting to cut out the shapes for you tools? I don't think either of the above suggestions will work then
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    I used a scalpel last time and it did ok but went blunt so quickly and ended up hacking it.
    Mr pee likes this.
    _G_
    _G_'s Avatar
    Jul 2011
    869
    vertical band saw. if not then clamp/sandwich the foam between two off cuts but not overly tight because you dont want it squashed, just enough to make sure it doesnt move around.. and jig saw it
    dantdi's Avatar
    Feb 2008
    kent
    511
    Ah, As already been said try soldering iron with really thin nib. But that is going to stink don't want to be breathing that in!
    Nice new stanley blade mite work just as well.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    all I got is basic saws, nothing like a band saw. Would love one.
    I might try a soldering iron.
    Need to find my gas mask.
    JRock247's Avatar
    Jul 2012
    Hampshire
    339
    May sound strange but an electric carving knife works pretty well, at least it did for me!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Ha ha
    Quote Originally Posted by ScottB5 View Post
    Isnt that under the bottom tier..
    Apr 2013
    15
    Use a brand new stanly blade as someone suggested already but keep swapping for a new one first sign of it tearing stanley blades arefairly cheap from Screwfix
  1. Cleaning light cut spot foam pads??
    By axelfols in forum Detailing
    Last Post: 9th May 2008, 15:42
  2. Ignition cut-off
    By lmankins in forum Classic Audi Forum
    Last Post: 18th November 2003, 14:18
  3. starting cut off
    By sahkel in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2003, 15:35
  4. Pro Cut Brake Lathe
    By DavidR in forum Other Brands & Models
    Last Post: 8th June 2003, 12:07
  5. Audi cuts A4 prices
    By amoffat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th January 2003, 22:59
