AH FabricationsVolks Autos
Results 1 to 9 of 9
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Problem fixing mates car
    Right before we start he owns a Rover 620ti ,i have spoke to him about his illness but he wont go and see the doctor about it [img]/ubbthreads/images/graemlins/bang.gif[/img]
    The problem is with the turbo as in lack of it ,no boost at all
    Hunts when ticking over
    Revs to 4500rpm under load but struggles to go any further with out a lot of engine noise
    My thinking it is the MAF?
    Checked for leaks
    Any help would greatful
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,885
    Re: Problem fixing mates car
    Sounds like RCS.
    Rover Car Syndrone.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Yea i know ..........have been told it could be a crank sensor loose know ?
    28v6
    Your on the right lines rev... look for the crank shaft sensor, clean until spotless then refit using carb cleaner.. also look for a camshaft sensor / hall sender and clean the same way and refit.. problem cured....
    Hunting on tickover could be the Idle stabilisation valve needing cleaned in the same manner and lubed with 3in1 oil.. then refit, don't panic if on refit the idle goes to about 1500rpm... it will reprogramme itself to the ECU, its like installing a new valve its not calibrated to the car.. also look for vacuum leaks , these also will make the idle hunt...
    pwnorman's Avatar
    May 2003
    north yorkshire
    402
    Think the problem could be solved by a good scrap yard.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    i said the scrap yard to but he just hit me,,,,,,
    Cheers 28v6 when it stops raining i will be on the case an dhope that sorts the problem
    28v6
    Any News Rev??? [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Working on it today or tomorrow been [img]/ubbthreads/images/graemlins/swear.gif[/img] down with rain here so not had a chance to look at it
    Will keep you posted
    60,000miles on the clock and having to do this OMG
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Right first look under the bonnet and a bit confused ,found the sensor for the camshaft took that off and cleaned up but could not establish were the maf was situated ,nothing connected to the air feed pipe going into the inlet manifold
    Anybody know and the crank sensor ?...Gings crivens thank god i have an Audi
