Chris NottVolks Autos
Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By johnnythepie
  • 1 Post By crazy88
Thread: Wood filler advice?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,836
    Question Wood filler advice?
    Question for you DIY guru's, as I'm stupid.
    What's the best filler to use on wood? I need to need to fill three holes left from metal door hinges - I say holes, they are more like cutouts - then I will paint over.
    Thanks.
    You've got to have a laugh!
    Jun 2011
    Great Melton Norfolk
    1,340
    Cut some pieces of wood just under the length/width you want and glue/pin them in then fill round the gaps.
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Quote Originally Posted by gen.heinz guderian View Post
    agreed... that way you can match the depth of the cut out to have a plush fit. You have a number of options... you can either sand the piece around all sides to get as good fit as you can or you can just slap a piece in and rely heavily on the filler to take over.
    I would say... sand the piece... get a good fit... and in any gaps, you could use a filler like Ronseal Woodfiller or make your own. Ronseal have a decent range to match various colours but always check the tubes as sometimes, people take the caps off and the filler is seized solid (give the tube a squeeze and that way you know it is fine).
    Making your own filler is easy too... all you need is a wood glue of your choice and saw dust. Saw dust is free... the panel cutter at your local DIY store will have loads in the panel saw dust collection bag or you may already have some on a work bench. If you use the saw dust from sanding/filing your the insert wood then you can also achieve a colour match that way. This may not be an issue if you are going to paint over it anyway but if you were using a darker wood for your home made filler then obviously you would need to paint over it to blot out the colour.
    Making your own: Make Your Own Wood Putty - Wood Filler
    Love DIY. Carpentry is in my blood so if you need any more advice feel free to PM.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,836
    Cheers guys, and there's me thinking of using filler for the whole gap!, pieces of wood first sounds good to me.
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    667
    Ive got a hole in my crap door from a erm... well my fist haha!
    Audi s3 goodwood green, BAM, n249 delete, 80mm TIP, s2000 air-filter, new turbo, ap coil overs, lots of poly bushes, 15mm spacers all round rolling on 18'' RSTT's
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,722
    I've got an old door that I bought to match the rest, it's a six-panel one which some retard fitted a modern handle to instead of the nicer original one. Anyway the dude at the reclamation yard recommended something like a small piece of broom handle in the circular hole and then sand down, but I've not tried it yet. It's currently a peep-hole to check up on the wife
    johnnythepie's Avatar
    handcrankywannkyspanky
    Apr 2009
    Coventry
    2,174
    Quote Originally Posted by crazy88 View Post
    Not a glory hole then???
    _G_ likes this.
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    crazy88's Avatar
    West Yorkshire
    4,722
    It's too big for that, i'm only thin...
    johnnythepie likes this.
    Apr 2009
    Coventry
    2,174
    i know the feeling.Been 'exercising' it for years.
    Pass me my sock
    Apr 2009
    Coventry
    2,174
    wont let me reply by pm!!
    Pass me my sock
    crazy88's Avatar
    West Yorkshire
    4,722
    Re: Wood filler advice?
    Quote Originally Posted by johnnythepie View Post
    That's because I was banned temporarily you should be able to reply now...although I suspect the moment has gone haha.
    Andie0's Avatar
    Aug 2012
    487
    Do these all day long not as easy as it seems to cut a piece of wood 3mm thick (size of a standard 4" butt hinge). over size your timber just slightly as without proper tools trying to get a piece of timber to 3mm is going to end up bloody! When you have a piece pinned (sink the pins to the depth required) then use a small block plane to skim the top off until perfectly flush then just fill with some decent two pack filler. Either this or a **** load of hand sanding, done right it should only take 5 minutes each one, becarefull using your sharp tools wear gloves
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
  1. Advice on cleaning piano black wood trim
    By Andy_S3 in forum Detailing
    Last Post: 16th March 2009, 10:01
  2. 2002 model S3 without bose - NEED UPGRADE ADVICE!
    By olly in forum In-Car Entertainment
    Last Post: 24th September 2003, 10:40
  3. Please HELP!!! Advice NEEDED!!!
    By AVerma in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2003, 16:34
  4. Advice on chipping MTM Vs AMD
    By Joules in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st March 2003, 03:20
  5. CD Burner Advice
    By Moresauce in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 31st January 2003, 12:05
