AH FabricationsBadger5
Results 1 to 30 of 30
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: Driving in the snow!!!
    Dec 2012
    47
    Hi, has anyone got any tips about driving in these current weather conditions. I have a B6 and 1.9 tdi avant 2 wheel drive and need to get to work but am scared about damaging it. Can I do anything to the car have more chance of arriving at work? Some of the roads here haven't been gritted.
    Dec 2012
    47
    Driving in the snow and ice!!!!
    Has anyone got any tips about driving in these current weather conditions. I have a B5 and 1.9 tdi avant 2 wheel drive and need to get to work but am scared about damaging it. Can I do anything to the car have more chance of arriving at work? like letting the tyres down a bit or getting studs, etc.
    Jun 2011
    Great Melton Norfolk
    1,356
    Keep a look out for Quattro drivers who think they are driving gods because they have 4wd!!
    Apart from that keep a greater distance than normal,use engine braking instead of having to brake hard.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Winter tyres are very worthwhile, but it might be a bit late for that now! Chains or socks are a substitute, if a bit of a faff.
    StateOfPlay's Avatar
    2,230
    Drive slowly. Don't accelerate sharply. Pull away in a low gear, so gear 2 rather than gear 1. Remember, your braking distance is virtually non existent if you stamp on the brakes.
    If you are going up a hill, don't stop unless you really have to. What I mean is, if your car starts sliding, just drive slowly but do not brake and stop as you will find it hard to get going again. Of course if you are going to hit another vehicle then you will have to stop.
    Follow the traffic in front of you and don't create your own lane on the motorway.
    Your journey will take longer. Plan for that.
    Take some water, your phone, a jumper or blanket.
    Stick to main routes if possible. I did that one year and went around the M25 and on to the A40 to get to work. Roads were in fair condition, but no other traffic on the roads! It was excellent.
    The last big bad snow that came down in the afternoon closed the M11 and the A1M. Took me 4 hours to do a 1 hour journey. But my mate got stuck as he left after me. He left work at 4pm, and got home at 8am. He was sat on the A1m all night long!
    Live your life as if nobody is watching you.
    Dec 2012
    47
    Which winter tyres do you recommend? I'd like a good brand but don't want to spend a fortune....Can they be used in the summer too? Thanks
    Dec 2012
    47
    Quote Originally Posted by StateOfPlay View Post
    Those are great tips! Thanks. Have you used winter tyres and know which is best? Thanks
    Mar 2008
    Dorset
    13,856
    They're designed for use at 7c and under. I can't recommend any myself, I always find quattro alone to be sufficient, but there are a couple of threads about on it.
    Dec 2012
    47
    Ok thanks, great tips!
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    751
    Sure I've seen good reports about Vredistein (sp).
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel|Stage1Map
    WANTED: Audi A4 B7 or MK5 5Dr Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Oct 2012
    Telford
    95
    If you have no chains or socks let a little bit of air out of your tyres.
    Avus Silver 2002 S3 BAM purchased Oct 2012
    Work Done To Do
    • Full Service
    • Sump and Pickup Clean
    • Rocker Cover Gasket
    • CV Joint Replaced
    • Top Mounts
    • New Rubber
    • Front stock ARB rear R32 ARB
    • DS Ball Joint
    • Haldex Service
    • Rear wheel arch bodywork
    • B5 Tip
    • Relentless DP and Sportscat
    • Custom Remap
    • RNS-E Install
    • Refurb Alloys
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,613
    Cannot recommend winter tyres highly enough... I run a set of mud/snow tyres as I got them for a good price... not exactly a winter tyre as they aren't much good when there is no snow but in the actual snow they are epic...
    Once these are worn (they literally only go on the car when there is snow forecast and they are on a spare set of wheels) I shall not hesitate to replace them with a suitable alternative... snow gets quite deep where I live (big estate on a hill) and they are night and day different to my normal road tyres...
    <tuffty/>
    robbiemac likes this.
    Dec 2012
    Hampshire
    137
    StateofPlay pretty much covered it, but I will add support for the winter tyres. To be honest I wouldn't worry too much on the make as even budget winter tyres will be better than most of the summer tyres we run in the UK. My missus runs Kumho's and they seem to work fine.
    Dolphin Grey B6 A4 Avant 1.9tdi
    Mods so far: Allard EGR delete pipe, Shark remap, Bilstein B12 Sportline suspension
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,613
    Quote Originally Posted by Johnjones View Post
    Tyre review is a pretty good resource...
    2012 Auto Bild Performance Winter Tyre Test | the online tyre guide
    I would not use them in the summer though... they are designed to be used at temps of 7deg or below...
    <tuffty/>
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,601
    The trick is throttle control, non of this 'I'm late for work' malarkey, everyone needs to just drive @5mph!
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,700
    Quote Originally Posted by gen.heinz guderian View Post
    Agree on both counts. We've already had the usual outbreak of posts from Quattro owners who just can't wait to get out there in the snow, as if it's a plaything.
    As for engine braking, that's a real must. If you have an automatic, put it into tiptronic mode, makes it so much easier to use downchanges to control speed.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    _G_
    _G_'s Avatar
    Jul 2011
    869
    - Avoid abrupt steering, acceleration and braking
    - Brake normally with ESP/ASR
    - Change to higher gear as soon as possible
    - Be careful of shaded areas, bridges and over-passes as the road is more likely to freeze sooner in these areas
    - If your car starts spinning, gently steer in the opposite direction
    - If the car does not react to you at all when spinning then you have no choice but to slam on the brakes
    - Carry a set of spare bulbs, emergency blanket and first aid kit
    - Respect the road
    - Laugh at cocky drivers but keep your eyes on the road i.e. my neigbour with his M3 who thought he could handle the snow but skid all the way up the road then again he is an a-hole
    - Follow any existing tyre tracks where traffic has gone through, sometimes when its bright and white its hard to distinguish hidden kerbs and pavements.
    - Remove as much snow fromy your car before you set off, nothing worse than a driver with 3-5 inches of snow on their roof and as they drive it just flys off onto everyones windscreen (sometimes in chunks) behind and obsecuring their vision.
    Dec 2012
    47
    These are all great tips! Thanks very much for all the input everyone! On all your advice, I went this afternoon and got some hankook winter tyres fitted on the front. It is amazing how it drives now...even in the slush it's got loads of grip and that combined with the ABS and ESP makes it a world away from old bangers I had in the snow in the past. Thanks again.
    Dec 2012
    47
    The hankooks were only £70 each fitted at elite tyres in Yate.
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Winter tyres really are amazing in this weather.
    Its about time they made it a legal requirement in this country and lowered the prices!
    My misis has winter tyres on her fiesta, and it performs much better than my quattro in the snow!
    Unfortuantely 18" winter tyres are far to expensive, otherwise i would get them for the audi, then it would be brilliant.
    Maritus Blue Audi A4 3.0 V6 S-Line TDi 275bhp, 585nm Torque
    Dec 2012
    47
    It's amazing the difference they make and like you say 4 x 4s can be left standing! I'm going to try and get a spare set of alloys so i can swap each year without balancing , etc. Anyone got any cheap 16" alloys for sale?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,700
    Something else to watch out for is the depth of the snow between your wheel tracks. If your car is lowered, or even if it isn't for that matter, the mound of snow between the wheels can easily start to scoop up between the sump and the engine under-tray, resulting in a broken under-tray.
    Feb 2009
    Aberdeen
    2,623
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Keep revs low, change up a gear when you can and try to keep everything smooth. If you start to slide/skid, don't just plant your foot on the brake, try to regain control first or you'll just lock the wheels and make things worse.
    Also, general winter tip, clear your WHOLE car of snow and ice, not just the windscreen. It won't get you to work any faster, but it's dangerous waiting for big chunks of snow and ice to either blow onto the windscreen or slip off the roof into the road or into you view.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Dec 2012
    47
    Do any of you guys know what ESP actually does??? It seems to stop lots of sliding somehow but I'd like to know the technical side...
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    292
    I got a set of 4 pirelli winter tyres 205/55/16 for £60 (Part worn) with 6mm of tread.
    Well worth it! big difference, just a bit noisy!
    kevbu's Avatar
    Aug 2010
    59
    I had a look around after I was amazed at how good my (same) car handled a snowy roundabout. Under steer, oversteer, it dealt with both.
    Electronic Stability Control (ESC) Revealed - YouTube
    Didnt know I had it but felt it and saw traction light flashing. I also have 4x winter tyres, both work well together but are not foolproof I'm sure.
  28. #27
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Never knew this. Saw someone get pulled over by the Police. He had a ridiculous snow afro on his honda... £60 fine and 6 points I heard the officer say. They followed him after he went through a gatso and his number plates were obsecured in frosted snow... so that will an extra 3 points and fine.
    Old article but the rules are the same, Rule 229 of the High Way Code: Drivers face £60 fine for snow on roof | Mail Online
  29. #28
    Apr 2012
    N. Wales, LL22
    1,224
    Quote Originally Posted by Dazmo View Post
    mm for mm they will be cheaper than your summers
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
  30. #29
    Apr 2012
    N. Wales, LL22
    1,224
    IMG_2296 by Ste_Nova, on Flickr
    VCDS in North Wales
  31. #30
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,096
    I have one tip, make sure you clear the whole of your car before making your journey.
    I couldnt believe how many cars I have seen in the past couple of days where they have literally done the wipers and driven off, all the side windows snowed under, boot, roof, bonnet and headlights all covered in snow too, is it worth the risk of an accident for yourselves, or even more so all these kids playing in the snow, it doesnt bare thinking about.
    Even worse, when the sheet of snow on the roof of the car in front sheds its load all over your windscreen when you are sat behind it.
    Anyway rant over
    Keep safe people.
    Nilz
  1. Driving In the Snow
    By will89 in forum General Automotive Chat
    Last Post: 16th November 2010, 21:14
  2. Driving in the Snow - Multitronics
    By will89 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th November 2010, 17:37
  3. A6 Quattro Avant driving in the snow (video)
    By reggieroo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th August 2010, 10:53
  4. Audi Quattro driving in the snow (video)
    By reggieroo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th August 2010, 15:52
  5. How do you drive your Automatic in the snow/ice?
    By gadgesxi in forum General Automotive Chat
    Last Post: 18th December 2009, 12:36
