Chris NottAH Fabrications
Results 1 to 1 of 1
    Oct 2012
    16
    Parking sensor fault, an unlikely solution?
    Had the rear and front bumpers spray painted the same colour as the body on my C5 allroad. My first thoughts were that either they had not been reconnected properly or the spray paint was too thick.
    On collecting the car discovered the parking sensors were not working and just gave a continuous tone when activated, also a few minutes later discovered the indicator bulb on the rear driver side had blown.
    I replaced the bulb and the sensors also started working again. Could this be pure coincidence or did the cars ECU detect an electrical problem, i.e. the bad bulb and disable the parking sensors in case they aLos had a related fault, i.e. causing them to fail safely?
  1. Parking sensor fault diagnosis with VCDS lite registered?
    By WhiteyAR in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th May 2011, 12:14
  2. Parking Sensors Fault 2005 Sportback
    By dave.ah in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th June 2010, 10:58
  3. Parking sensor fault on 2005 b7
    By Sirwacko in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th February 2010, 22:14
  4. Aftermarket Rear Parking Sensors
    By hfu in forum Detailing
    Last Post: 15th April 2004, 14:15
  5. Retro fit Parking Sensors
    By 18ME in forum General Technical / How To
    Last Post: 17th June 2003, 15:49
