Sky InsuranceVolks Autos
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Wicked666
Thread: Any plumbers about?
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    Any plumbers about?
    Just moved into a new house and was wondering whether I could fit a host pipe to the mains stopcock that is in the garage?
    I'm not sure but seems ideal for using with my Karcher on the car.
    Dec 2011
    396
    it looks like there is a pressure valve to down the pressure before it gose in to the house so you could cut the drain off fitting on the right put a outside tap in its place as it will work as a drain of in its place . hope it helps
    Mar 2010
    112
    If you connect pre-pressure reducing valve make sure you dont use those cheap tap fitting kits, but instead just use brass fittings!
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    Thanks guys. I'm only renting the house so do not want to cut anything. Could I not just connect a thin hose the the bit dangling down (secure with metal clips) and turn the valve above it? Or is that not recommended? Alternative is hose through kitchen. Thanks.
    Chugger
    North Devon
    2,716
    Any plumbers about?
    Get yourself a 22-15-22 compression tee, a couple spare olives a bit of 22 tube, a bit of 15 tube, a new drain off, a compression 15mm equal tee, 15-1/2" back plate elbow and a bib tap with check valve. Then you will have everything you need to DIY
    57 A3 2.0 TDI Sportback (140)
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    Quote Originally Posted by sportstractor View Post
    Thanks but didn't understand a word of that so bought this:
    Will be feeding a hose outside the kitchen window instead
    johnnythepie likes this.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    lol! It will do the same job to be fair.
    Dec 2011
    396
    you could just put the hose over the drain off on the right with a jubley and use a small spanner and open it when you use it . it just turns and opens
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    Quote Originally Posted by harvey01 View Post
    That was what I thought and was hoping the answer would be 'yes'
    Would this cause any issues with the stop cock though?
    Chugger
    North Devon
    2,716
    Any plumbers about?
    Lol, you could do that but it would be against water regs, as dirty water could potentially be sucked back into the water main. And it would be pretty annoying to use.
    If you looked in B&Q you could find everything I listed and fitted a proper tap in under an hour.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    Quote Originally Posted by Wicked666 View Post
    If you have already purchased this, then just use it, it perfectly fine, and works! Unless this hose has to go round the whole house of course, but I wouldn't mess with the pressure release valve personally.
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    Thanks guys - don't want to do anything that could make the water dirty. Hose does have to go round he side of the house but no real issues. Only risk is these taps have a habit of popping off but i'll put a bucket over it to protect the kitchen
  1. any admin about?
    By _G_ in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th July 2012, 20:30
  2. HELP!!! NEED IF ANY ONES ABOUT
    By jay6392 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th May 2012, 15:23
  3. Any plumbers on the forum?
    By TDI in forum General Chat
    Last Post: 29th October 2006, 10:29
  4. Any one know about these.
    By Markey in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st November 2004, 20:07
  5. Any car insurance experts about?
    By imported_Yaseen in forum General Chat
    Last Post: 26th October 2004, 18:36
