Revo TechnikDTUK
    pink.teg's Avatar
    Jan 2012
    Cardiff
    103
    Post Thanks / Like
    suspension question
    hi all
    been looking for some new suspension set up and have or will buy
    B12 set for my A4 B6 tdi sports quattro
    please look at the diff
    1. Buy Audi Bilstein B12 Tuning Suspension Kit | PPCGB
    2. AUDI A4 (8E2, B6) 1.8 T Quattro, 1.9 TDI Quattro, 3.0 Quattro Bilstein B12 Pro Kit Suspension Kit B90-15-006-09-22 Only �600.10
    why is one saying The unique B12 dampers significantly influences traction, over steering and under steering in perfect harmony with the Bilstein developed H&R springs.
    and the other saying
    This kit uses Eibach Pro Kit springs and Bilstein B8 Dampers for the best in ride quality and handling
    which one do i buy ??????
    thanks alan
    ps which one do i pick Lowers car by:
    - Front: 45mm
    - Rear: 45mm (axle load to: 1150kg)
    2 OPTIONS:
    - Front Axle Weight upto 1140kg
    - Front Axle Weight from 1141 to 1220kg
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    3,264
    Post Thanks / Like
    You would probably be better off posting this thread in the B6 owners forum, rather than in the General Chat section. Far more chance then of getting an informed response from someone in the know.
    Jeff:
    A4 3.0TDi SE Quattro Tiptronic
    Life is what happens to you while you're busy making other plans.
  1. suspension question
    By Adam-D in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th May 2009, 11:18
  2. Not another suspension question!
    By Ozzyb in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2008, 18:43
  3. another suspension question!
    By btmotorsport in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2008, 22:02
  4. suspension question
    By audi_driver in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2006, 13:42
  5. Suspension question
    By noslojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2006, 17:48
