Revo TechnikW8 Performance
    macpdm's Avatar
    Jul 2011
    Cheshire
    356
    Post Thanks / Like
    Help with leaking soil pipe
    Afternoon all
    I have a problem I could really do with some help with please guys.Our home is a shared property and about 5yrs old.Maybe 1 - 2yrs ago We had an issue with a leaking upstairs toilet wastepipe which was repaired and the ceiling replastered and repainted.Now the problem is back again im guessing because of poor installation and the ceiling will probably have to be repaired again.In fairness to the property management people they organised and covered the costs on the first occasion but they dont appear to want to know on this occasion.Can I take this up with NHBC or any other body to get this fixed once and for all.Or do I have to suck it up and cover the costs of repair myself ?
    Thanks all
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    8,035
    Post Thanks / Like
    Surely that should be covered under a 10 year NHBC warranty, I would look further into that, also may be worth contactig your home insurance to see if its covered.
    Maybe worth getting in touch with the Citizens Advice Bureau and see if they can help at all or advise on the best cause of action for you to take.
    Hope you get it sorted.
    StateOfPlay's Avatar
    737
    Post Thanks / Like
    You have a leak, you need to get a plumber out to stop it.
    Once a plumber has been out, they can advise you whether it is an installation problem, or just a bit of bad luck that affects us all from time to time. If it is an installation issue, then you can take it up with the home builder, then the NHBC.
    Thing is, the damage caused by the leak is covered under your buildings insurance, and that I assume is arranged by the management company. So they need to be a little more helpful than they appear to have been.
    So, you need to get the problem fixed, the insurance will pay to repair the damage caused by the leak, and then you can take up the issue of why it is leaking with the builders/management company/NHBC if the plumber says it is a build problem, not just an unlucky leak.
    Audi A4 1.8T Sport Convertible. Multitronic.
    macpdm's Avatar
    Jul 2011
    Cheshire
    356
    Post Thanks / Like
    Cheers guys
    Plumber has been and has repaired the problem which he believes should resolve it although he was very unimpressed with the install.I have spoken to the ombudsman who has advised me to obtain a copy of the complaints procedure from the management company.I have done this which seems to have put the willys up em especially when they asked why I wanted a copy.
  1. Leaking turbo pipe
    By ScottB5 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th February 2012, 19:09
  2. boost pipe seals leaking?
    By Trucker_Anders in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th September 2011, 08:50
  3. boost pipe seals leaking?
    Last Post: 24th August 2011, 16:39
  4. Leaking Oil Feed Pipe
    By alex-qts in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd June 2010, 20:04
  5. 2.0 TDI DSG - Leaking Oil From The Intercooler Pipe?
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd February 2010, 20:00
