Backdraft MotorsportAWEsome GTI
    Nov 2011
    Post Thanks / Like
    PLEASE HELP A3 TDI NOT STARTING
    Please if there is anybody out there that can help. It started when i blew my head gasket the head was so bad i had to replace it, i got a second hand one i also replaced my turbo and overhaul my injectors. At first it would not start at all got a second hand fuel pump started fine but only if i close the return fuel line once i leaf it it will cut out, got the pump changed but now it only cranks over and doesnt start at all. I am totally confused this is being going on for a month and no cash and still no Audi if there is anybody out there that can help PLEASE i will appreciate it.
    quattrojames's Avatar
    Mar 2008
    Dorset
    10,988
    Post Thanks / Like
    What year is your A3 and I'll move it into the right section for you?
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    Nov 2011
    Post Thanks / Like
    It is a 2004 model
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,021
    Post Thanks / Like
    fuses
    wiring connectors
    glow plugs
    Current mods
    Forge 007P, front mounted intercooler, smoothed airbox with jetex panel filter, boost gauge, broadband AFR, 312mm brakes, 3" downpipe/decat,straight thought, s/s backbox, stage 1 remap, coilovers, silicone TIP
    WantedS3 upper strut brace
  1. AUDI A3 1.9 tDI not starting
    By hancliff79 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th August 2011, 17:15
  2. 99 A4 tdi starting probs
    By Maverick1888 in forum Diesel forum
    Last Post: 12th June 2010, 18:39
  3. A4 TDI STARTING/MPG/HELP!
    By vw754 in forum Diesel forum
    Last Post: 29th January 2007, 00:40
  4. starting a4 tdi probs!
    Last Post: 24th January 2007, 15:06
  5. starting problem! tdi
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2006, 10:16
