Badger5Sky Insurance
    DaveACQ20v's Avatar
    Nov 2004
    UK south west
    429
    Losing a Remap ?
    I think we all know by now that you can reset your ecu by disconnecting the battery for half an hour. But what happens if you`ve had a remap ? does it go back to original config ? If it does you could lose 500 worth of remap just by having a starter fitted, unless some sort of code saver for example was used. anybody know ?
    i havent got a remap, i just want to know. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    Re: Losing a Remap ?
    [ QUOTE ]
    [/ QUOTE ]
    I'd *guess* that it shouldn't be affected, as AFAIK a map is coded into the ECU in a similar way to a flash-EEPROM; and as such the memory becomes non-volatile after the writing-process is complete.
    That said though, I remember reading on one of the forums someone had a suspicion of losing a remap after battery disconnection/replacement - I'm not sure how that panned-out though; and whether it ever became a confirmed cause or not.
    Regards,
    Rob.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    I have done this and my remap was fine afterwards...
    Still pulls like a *****.
    Oct 2003
    South Wales
    2,942
    Don't worry, you won't lose your remap....
    Rich
