Chris NottAH Fabrications
    imported_kbininger
    Ingnition Switch
    I need to replace the ignition switch on my 96 A4 2.8. Is this switch programmed to the key or ECU? In my Infiniti, the key has a chip that must be programmed or the ECU is disabled, and that can only be done by the dealer. Needless to say, they will not work on a used part so I would need to buy it from them.
    I can get a switch for my Audi on car-parts.com for less than $100. The dealer part is $400+. Will I be able to just install the used switch or will it need dealer programming?
    Thanks for your help!
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: Ingnition Switch
    If you are just replacing the key reader, then you do not need to have the keys reprogrammed AFAIK.
    I can check this for sure later when I get home from work.
    imported_kbininger
    It would be the ignition key assembly. My key is stuck in the switch and I can't get it out.
