    Apr 2010
    2000 S4 B5 question
    Hi,I am new to the site,I have a 2000 S4 that seems to be having a voltage regulator issue.
    What is the best way to gain access to the alternator cos I can barely see it.I read about a "service mode"
    but this seems like alot of work for an alternator.....
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    There might be something of use here: http://www.audidiy.com/b5s4.html
    What do you make of the B5 S4? I was thinking about one after my A3 in a couple of years as they're not masses to buy. Have you had any issues with the turbos or reliability in general?
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Apr 2010
    Thanks ill take a look.I have only owned the car now for a few months and the only other problem ive had is a bad oil temp sensor which was cheap to replace,so,so far so good!The S4 is the first Audi I have owned and honestly I cant find anything to complain about.I have a cool air intake,15lbs flywheel,stage2 clutch and a Borla cat back exhaust.The car has bags of torque,it will pull away hard even in 6th at 40mph.So yeah id definitely recommend the car!
