AH FabricationsChris Nott
    Sep 2009
    worcester
    1,097
    caliper carriers
    hi guys, im after a pair of 323mm caliper carriers for my s3 8l
    im downsizing from 355mm 2 piece discs to 323mm one piece discs, only reason im going for 323mm discs is to retain my 6 pot porsche calipers, think 312mm would be too small?!
    anyhoo, was wondering if any audis/vw's use 323mm discs as standard and therefore utilise their carriers, have searched hi and low and cant find anything useful
    failing that could anyone point me in the direction of a company who could help
    thought i would post this in here to get a wider audience, but mods feel free to move as you see fit
    thanks in advance
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    Only the mk1 LCR uses 323mm disks and Brembo's out the box, but those carriers are designed specifically for the LCR calipers, so probably won't be of any use to you, and they are not cheap neither.
    323mm solid disks are approx Ł100+vat each also, why don't you try using Golf4 R32 disks? They are 340mm or there abouts and single piece.
    You've got to have a laugh!
    Sep 2009
    worcester
    1,097
    Quote Originally Posted by jojo View Post
    ahhhh, why thank you very much sir!! never even gave the r32 a thought
    i shall investigate, hopefully pick up a pair in a scrapyard fairly cheap, stealers will be a rip off, as per normal lol
    oh also, when you say about the lcr carriers only for brembo calipers, isnt brembo a supplier to porsche and would, in theory fit my calipers?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    Quote Originally Posted by jonny87 View Post
    Wish it was that easy, each caliper is designed differently, and need correct spacing to match the disk offset, or we would all go out and buy 6 pot calipers, LCR carriers and do the conversion instead of paying Ł2k+ that someone spent to have it fitted on your car.
    Sep 2009
    worcester
    1,097
    lol yer, never thought of that!
    thanks again for the replies matey
