JMB RetrofitsChris Nott
Thread: Hub distorted!?
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Hub distorted!?
    Long story short, warped a set of discs within 2 months so bought a new set of Brembos.
    Fitted them today but when I spin the wheel I got this (watch video)
    http://www.youtube.com/watch?v=uNfbLCqVhm8
    1 Wheel seems to be catching on the pads when I spin it pointing to distortion of the hub?
    The bearings are fine, no play at all.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    UPDATE:
    Took off the disc and checked the hub for run-out:
    http://www.youtube.com/watch?v=sJvrweb7QiY
    Basically nothing.
    then fitted the disc on a totally clean hub that I ran the sander over to remove all traces of rust and got this:
    http://www.youtube.com/watch?v=x8B2B3bPYJw
    .20mm of run out on brand new brembo discs.
    I'm at a loss.
    Chris
    See my images @
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Can you position the disc in a different position to see if it improves per chance?
    Or is it one of the grub screw mounted jobbies
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    grub screw jobbie, although I could move it and bolt it back on
    Chris
    See my images @
    Apr 2004
    12,523
    for gits and shiggles it has to be worth a try to see if you can improve upon it
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Moved the disc to several different positions, same run out at some place on the disc each time (marker pen helped)
    2 sets of out of spec discs from 2 different retailers, what's the chance of that?!
    I'm going to go and look at an A6 LeMans next week.
    Chris
    See my images @
