Chris NottVolks Autos
Results 1 to 7 of 7
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,504
    Stuck fast, rounded nuts!
    Hi,
    Not on my Audi but a friends Vectra C i'm working on. Vauxhall has used copper nuts on stainless steel thread for the Exhaust manifold.
    Out of the 10 nuts, 5 have come off no problem. 2 have stuck to the short thread rod and undone that...so still not an issue.
    BUT 3 are stuck fast and one has rounded off badly, two are rounded a little. They are 10mm nuts so I've tried heating them with a blow torch (which helped with 3 of the others), they all had plenty of doses of WD40 over the week running up to the removal.
    Apart from acetylene gas, has anyone used any tools/special sockets for removing rounded nuts? The copper is really soft on these nuts and access for a junior hacksaw is a no go.
    If you have any other suggestions or ideas please let me hear them. My friend, doesn't want to pay a local garage to fit the replacement Manicat.
    Cheers,
    Dan
    2002 2.5 V6 Quattro
    347
    347's Avatar
    Sep 2006
    223
    hi , I bought a stud removal set from Halfords , they look like a deep socket and cost about £20 might be worth a go , either that or try and get the offending nut hot and try using a 3/8 socket , slightly smaller than 10mm
    2010 2.0 Tfsi BE ibis white DSG , now sharked
    Nov 2013
    Heath Hayes
    639
    I know the pain you are feeling, used to have a vectra and had to remove the manifold due to studs breaking causing the manifold gasket to blow.
    On any nuts like that I use wall drive sockets or spanners.
    You are much less likely to get into the problem you have. I have managed to undo nuts on other peoples cars that have been rounded off with traditional sockets using my wall drive ones.
    If all else fails then A pair of mole grips can do the trick if you can get them in or a nut splitter.
    Buy Silverline PC70 Nut Splitter Set 2pc from our Hand Tools range - Tesco.com
    After that I usually resort to the angle grinder if you can get it in there. Just slice off one side of the nut. You will have to replace the stud but when I was taking off the manififold on mine I replaced them all anyway as there was an upgraded part that wasn't made of toffee.
    Karl.
    Sep 2013
    Portsmouth
    160
    I use these when nuts and bolts get rounded: Irwin Bolt Grip Nut Remover Set 5 Pieces | Screwfix.com
    S4_dan's Avatar
    Jan 2006
    1,504
    I've tried 3/8 and even a 9mm after using the 3/8. Still rounds off due to the copper being so soft! ridiculous idea to use copper nuts if you ask me.
    Will have a look at the above ideas and order something.
    cheers guys for your input.
    Dan
    2002 2.5 V6 Quattro
    Tom5190's Avatar
    Oct 2013
    Teesside
    131
    The Irwin set above will see you right, I've got a set and never had a rounded bolt problem since I bought them. Probably one of the best tools I've ever bought.
    The only issue you can get with them is getting the space to hammer them on, sometimes it just means you may have to remove a few other things you wouldn't usually.
    S4_dan's Avatar
    Jan 2006
    1,504
    I ended up buying a Irwin set. They have arrived and look to be very well made, decent quality. Will hopefully be attacking the nuts next week.
    Cheers,
    Dan
    2002 2.5 V6 Quattro
  1. wheel nut rounded off
    By mikey75 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2013, 20:41
  2. help needed FAST, stuck on remoal of rear wiper.
    By supanova in forum General Automotive Chat
    Last Post: 8th March 2011, 14:31
  3. Replies: 10
    Last Post: 27th October 2010, 20:44
  4. Seating position when driving fast. Turnfast web
    By rodfj in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2009, 19:02
  5. Stuck Nuts!
    By Twinkle666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2007, 12:19
