Chris NottBadger5
    Allmine's Avatar
    Apr 2013
    27
    Brembo Cupra R calipers on an Audi TT 225 help please?.
    Hi all, hope I can get some help on this as I'm a little stuck as to what to do.
    I've bough these LCR brembo calipers and want to fit them to my TT but cannot seem to find the brackets as the ebay seller says there are two types of Cupra brembos and the dealers are saying they don't have a clue if the OE Brembo brackets fit as I haven't been supplied with any brackets so won't know.
    Will the Brembo brackets bolt straight on the TT or do I need alternative fittings?.
    Is there anyone that knows how too or can help me in the right direction please?.
    Also if anyone needs uprated brake lines for ANY Brembo Calipers I have bought a front pair 28inch in length off Thomas @ "PorscheCalipers.co.uk" who was very helpful and at a very good price.
    Many thanks
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    If you have purchased genuine LCR calipers, then you need OEM LCR carriers, and they bolt directly to your hub. You obviously need the correct discs, pads and braided brake lines to finish the conversion, and have wheels that clear the calipers! OEM 18" RSTT alloys need 10mm spacers to clear.
    Allmine's Avatar
    Apr 2013
    27
    Jojo, thank you for yor reply mate, the TT forum were not as helpful with sarcastic comments on why don't I go on the search box when I was clueless to the site.
    I've brought the calipers discs pads as a complete set minus the brackets but I really appreciate your reply as you've also added I need wheel spacers which is very helpful
    I will get these ordered ASAP as there is a seller called creation motor sports who are selling these brackets for £99.00 + carriage so should have them mid next week.
    I've also just fitted 15mm spacers bought from a seller in staffs for £55 including 10 extra 50mm wheel bolts for my 20mm spacers bought a whole back so all I need to do now is get my rstt rims powder coated and fitted on with the calipers discs etc.
    Then fit my 3" Dp and a re-map to match.
    I ordered braided hose on Friday and received then this morning super fast delivery from porschecalieprsltd :-)
    Only other thing is to have these calipers painted as they've seen better days lol
    Thanks again 😊
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    Sounds good, post some pics up once all fitted! I tracked my S3 today which has Brembo GTs up front(LCR spec), and they performed well, so you should be happy with yours once fitted.
    Allmine's Avatar
    Apr 2013
    27
    That's music to my ears as the OEM brake set up aren't very good for track!.
    Will post some pics up once all fitted.
    Thanks again
  1. K04 Conversion On Audi A3 AGU HELP PLEASE !!!
    By Chester999 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th October 2012, 11:36
  2. Audi Drive Select help please
    By golfather1 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 6th August 2012, 14:24
  3. Audi a3 suspension HELP?? please
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2010, 21:50
  4. audi a4 2003 help please
    By ngoncalo in forum General Technical / How To
    Last Post: 16th July 2007, 04:05
